Looking for a 4-hole twin 13A metal pattress box
Home Forums The Tea Room Looking for a 4-hole twin 13A metal pattress box
  • #632730
    Greensands
      @greensands
      Anyone know (or may even have one available) a source of a top and bottom 4-Hole metal pattress box to fit the twin 13A MK socket shown in the photo. Most commonly available boxes these days, metal or plastic are for two hole fixings mounted along the sides. Do not like the idea of throwing out a perfectly good item which imo was made to a much higher standard than similar items marketed today.
      #37139
      Greensands
        @greensands
        #632733
          Would it mount on a pair of sideways single pattresses? Or maybe one of these, example is Toolstation
          Not sure MK did anyone any favours when they designed that. The layout may be deliberately non-standard to stop light-fingered employees nicking them. There are a few variants:
          Some at work had vertical live and neutral rectangular holes rather than horizontal.
          Greensands
            @greensands
            The Toolstation option is a thought but the centre section would need to come out. Would also need to check the hole centres.
            #632738
            Harry Wilkes
              @harrywilkes58467
              #632740
              Engine Builder
                @enginebuilder
                That's a socket from the MK metalclad range and the box to fit is smaller than a metalbox designed for mouning a socket flush in a wall. The correct  box is the same shape as the socket with round coners and is pressed steel.
                Edited By Engine Builder on 09/02/2023 16:05:31
                #632743
                Martin Connelly
                  @martinconnelly55370
                  You could make some suitable pillars and mount them in a standard box. You may have to add a frame to ensure there is no gap around the edge.
                  Martin C
                  #632744
                  DC31k
                    @dc31k
                    The Toolstation one will not work. Twin single gang is larger than one double gang.
                    Pay good attention to the caution from Engine Builder, but verify the truth of what he says by testing the socket you have on a double backbox to make sure the radiused corners do not underhang.
                    The art deco emporium kit is just a very expensive version of these:
                    https://www.cityplumbing.co.uk/p/back-box-repair-clip-pack-of-5-bbrc1444/p/638067
                    The key search term is 'back box repair clip'. They fit a standard double backbox.
                    #632748
                    Oven Man
                      @ovenman
                      Engine Builder is correct. It requires a surface mount box from the MK metalclad range, if they still do them.
                      Peter B
                      Looks like the design has been updated by MK, finding an old style box might be difficult.
                      Edited By Oven Man on 09/02/2023 17:07:39
                      #632750
                      Dave Halford
                        @davehalford22513
                        Harrys vintage link implies 1970's so maybe 50 year old plastic, I know I was in better nick back then than now.
                        You could weld 2 singles together to get the right screw spacing, but you will probably still get get gaps at the four corners.
                        #632751
                        DC31k
                          @dc31k
                          Does the white bit remove easily from the metal surround?
                          If so, buy one of these:
                          https://www.cef.co.uk/catalogue/products/114579-2-gang-blank-plate-metal-clad
                          cut a suitable hole in it and for £1.50 you have a double socket socket that will fit a modern backbox.
                          #632777
                          Emgee
                            @emgee
                            Those sockets went out many years ago as said by others, my choice would be to cut an aperture in the lid of an adaptable box and fit the socket with screws and nuts to the lid, then connect in the usual way.
                            When purchased the socket would have usually been mounted on a metal box to the plate dimensions although there was an option to buy the bare socket for fitting to your own equipment, a metal frame was available that had the 4 fixing points tapped and the frame was fitted behind the cut out aperture.
                            box on eBay 263712560450 may not be long enough but otherwise suitable 141x81x39.5mm (Plastic)
                            Metal eBay 181302507015
                            Emgee
                            Edited By Emgee on 09/02/2023 19:18:53
                            Edited By Emgee on 09/02/2023 19:31:48
                            #632813
                            peak4
                              @peak4
                              Posted by SillyOldDuffer on 09/02/2023 15:38:29:
                              A little video for you; we used several different designs at work, e.g. a secure supply would feature T shaped earths, or some computer kit would be a different shape to stop the cleaner using an adjacent socket etc.
                              A Little bit here about the old 4 screw sockets.
                              https://flameport.com/electric_museum/sockets_13A_BS1363/mk_socket_outlets_double.cs4
                              Bill
                              #632817
                                If you are that bothered about reusing it and a metal worker why not get a current 2 lug one and silver solder on 4 mounting lugs to suit the old layout.
                                Myself I doubt I would bother and just get a new one which with far less plastic on the front offers more resistance to damage that that old design which is the reason why Metclad are used in garages and workshops.
                                #632835
                                Engine Builder
                                  @enginebuilder
                                  In my working life as an electrician one job we did used special 13amp sockets in some locations where only specific
                                  appliances could be pluged in. The plugs and sockets at first glance looked like normal ones but they had all the pins rotated 90 degrees.
                                  #632842
                                  Nealeb
                                    @nealeb
                                    Way, way back in my school days I had a job in a local television and radio shop. Sometimes helping with repairs but mainly out on the van helping deliver fridges and colour televisions – a two-handed job in those days. One day, we delivered to a guy who has just refitted his kitchen, and he very proudly showed us the waterproof 13A sockets that he had picked up where he worked and had now fitted in his new worktop. I asked him where he could get the matching plugs. Yes, the ones with pins rotated 90°. He wasn't very happy when we left…
                                    #634226
                                    Ed Duffner
                                      @edduffner79357
                                      MK make there parts in ranges, e.g. Logic Plus range or Sentry range. There might be a 'range' imprinted into the plastic on the rear of the socket outlet and could simplify searching for a box.
                                      Edit: Just having a quick scan of the web I came across this: https://www.art-deco-emporium.co.uk/Vintage-MK-4-Hole-Socket-or-Switch-Fitting-Kit-for-Existing-or-new-Backboxes-1158
                                      …will update if I find more.
                                      Ed.
                                      Edited By Ed Duffner on 19/02/2023 17:43:02
                                      #634241
                                      V8Eng
                                        @v8eng
                                        The up to date modern standards MK version of that box and socket is about £15 at various wholesalers. Sorry to say it but personally I find it very difficult to see any point in hunting for an ancient bit of kit like that.
                                        No personal offence whatsoever intended.
                                        Edited By V8Eng on 19/02/2023 19:26:54
                                        #634317
                                        Greensands
                                          @greensands
                                          Problem now sorted having bought the plastic box suggrested by Emgee. The modification required a lot of time which I dare say others would have considered as wasted time but have achieved a presentable result which does look far neater on the bench than the previously old domestic model ever looked. Thanks to all those who provided assistance.
