Clarke CL500M
Clarke CL500M
  • #506352
    Simon Ravenscroft
      @simonravenscroft79077
      Hi I am looking for a little help please, I have a Clarke CL500M and I know its a "toy" compared to the real machines out there I can only dream of owning but as I only use it to make small hobby Nixie clock parts it works for me.
      I have decided to make myself a nixie watch which needs a large watch face (70mm)and if that wasn't hard enough I have decided to make it out of titanium, this could go horribly wrong but hey you only live once.
      My real problem is that my CM500M only has a 3 jaw chuck that opens to about 60mm so I need more,
      I have seen these Model Engineering and engineering tools online from RDG Tools Ltd Home Page (Engineering Tools) Tel 01422 885069 /884605
      but after emailing them they said they are for their own chucks and may not fit mine.
      Can any one help me find a set of 5" outside jaws for the CL500M in the UK
      OR does anyone have another inexpensive way to work the problem.
      The titanium bar is 70mm dia x 40mm but I only need it to be about 20mm long the other 20mm is sacrificial for the lathe to hold
      Many thanks
      #33718
      Simon Ravenscroft
        Help with chuck
        #506403
        Nick Clarke 3
          @nickclarke3
          Have you tried Machine Mart Spares? 0871 410 1270
          #506406
          Simon Ravenscroft
            I Have now, they said they have some outside jaws for £77.72 but he could not tell me what size they were or any other information, a lot of money to spend on something that may be the right one
            Thanks for the suggestions
            #506434
            john halfpenny
              @johnhalfpenny52803
              Don't apologise; the lathe can produce good work. The three jaw should have an external jaw set, which can be seen in the MM catalogue. These will hold 100mm with all of the jaws within the chuck circumference, so plenty of capacity for you ( and much more if the jaws protrude)
              #506439
              Simon Ravenscroft
                I have to admit I bought the late second hand and it came with some other items though I have not checked, there may well be some but I doubt it I'm sure I would have noticed/remembered
                #506516
                Simon Ravenscroft
                  Posted by john halfpenny on 10/11/2020 13:24:39:
                  I have to say a big thank you, your right it does come with a spare outside set, I should have looked in the box surprise
                  That's my problem solved
                  Thanks John
                  #506527
                    That's £77 saved in 9 hours, come up with enough queries like that and you could almost make a living out of the forum
