D 13 chuck backplate stud fitting not camlock
Home › Forums › Help and Assistance! (Offered or Wanted) › D 13 chuck backplate stud fitting not camlock
  • #274460
    richard perrin
      @richardperrin87256
      Hi, Trying to find a supplier of Di3 Backplate for Myford 254s lathe, it has the stud fitting not camlock, the ones that I have looked at Warco etc seem to have a very shallow register. I want to fit a 4 jaw ind chuck, failing that maybe a 4 jaw with D13 fitting. any help would be appreciated.
      Regards Richard
      #32861
      richard perrin
        @richardperrin87256
        #274484
        Old School
          @oldschool
          Richard. I have used the warco D13 backplates on my 254s you just have to make the studs. I use cap head bolts with a plain shank and thread it M10x1 to fit the backplate use a good die to cut the thread the bolts are tough. The register in the warco and a cast iron back plates I have used is correct.
          #274511
          richard perrin
            @richardperrin87256
            Thank you Old School, I will try one from Warco, what do you use for lubrication in the headstock / gearbox?
            Many Thanks. Richard
            #274526
            Old School
              @oldschool
              I use Machine/slide way oil 68 from Arceurotrade
              #274533
              Old School
                @oldschool
                Forgot to say also use this oil in the saddle and the bed etc.
                #274578
                richard perrin
                  @richardperrin87256
                  Thank you again Old School, Regards Richard
