Emco compact 5 chuck key help!!
Home › Forums › Help and Assistance! (Offered or Wanted) › Emco compact 5 chuck key help!!
  • #32840
    Patrick McMahon 1
      @patrickmcmahon1
      #268284
      Patrick McMahon 1
        @patrickmcmahon1
        Hello,
        Can somebody advise what the correct size is for the replacement chuck key on the Emco 5 compact lathe?
        The chuck is the 3 jaw type with a drill type fitment.
        I’ve lost my key during a recent ‘clean up’ session in the garage 😔
        #268303
          Depending when it was made Emco used Rohm chucks which should have a model mumber on the chuck. You should be able to look that up and find a suitable key.
          #268310
            Douglas Johnston
              @douglasjohnston98463
              You are not alone Patrick, I have the same chuck which I had not used for ages and now can't find my chuck key either. I think my workshop elf must have been speaking to yours. I am hopeful that mine will turn up, but if not, can you post on here any success you have in locating a supplier.
              Doug
              #268329
              Emgee
                @emgee
                Patrick
                Measure the spigot hole on the chuck and search for a Jacobs K number chuck key that has the same size spigot is a good start point, there may be a choice of 11 or 12 teeth, can't remember which it is. You will have to make and fix an extension to the stem for comfortable use.
                Emgee
                #268347
                Hacksaw
                  @hacksaw
                  Patrick , paint your new chuck key banana yellow . yes All my chuck keys are painted yellow , and do you think i can find the right one when i need it ? sad
                  #268417
                  mark costello 1
                    @markcostello1
                    It's probally hiding with the bananna's.wink
                    #268438
                    Enough!
                      @enough
                      Posted by Douglas Johnston on 25/11/2016 09:56:02:
                      …….can't find my chuck key either. I think my workshop elf must have been speaking to yours.
                      I think perhaps they both have been trading with mine. I seem to have an oversupply of the things that I can't match with chucks. You wouldn't, either of you, have seen a 1/8" ball-ended allen-key screwdriver with a blue handle?
                      #268444
                      Hacksaw
                        @hacksaw
                        When i was small , if i broke one of my Dads tools , i would hide it , so i didn't get into trouble laugh
                        I've lost a bit of crosslide…. blush
                        #268471
                        Douglas Johnston
                          Posted by Bandersnatch on 25/11/2016 22:50:19:
                          ​Sorry Bandersnatch, I just wish my elf would pinch the odd item from elsewhere but he is just interested in hiding my stuff. Only just noticed he has hidden my 6" steel ruler again.
                          Doug
                          #269174
                          Patrick McMahon 1
                            @patrickmcmahon1
                            Thabks you all for your help – it’s a Jacobs #3 for anyone who needs to know!
                            I found it hiding in the swarf bin….
                            #269182
                            Emgee
                              @emgee
                              How many teeth Patrick and diameter of spigot end please, can put the info on the Emco 5 lathe site for reference.
                              Emgee
                              #269202
                              Patrick McMahon 1
                                @patrickmcmahon1
                                Emgee it’s 11 teeth and the spigot has a 6.9mm diameter
                                Where do I find the Emco 5 lathe site? Is it on here?
                                #269225
                                Emgee
                                  @emgee
                                  Hi Patrick
                                  Thanks for those dimensions.
                                  I am a member on the Yahoo Emco 5 cnc site but there is also a dedicated Emco 5 manual lathe group on Yahoo, link to the cnc group **LINK**
                                  Emgee
                                  #269264
                                  Patrick McMahon 1
                                    @patrickmcmahon1
                                    #269265
                                    Patrick McMahon 1
                                      @patrickmcmahon1
                                      #273457
                                      mike T
                                        @miket56243
                                        Hi Patrick,
                                        I have also lost my EMCO chuck key. so I followed up on your information, but drew a complete blank.
                                        The Jacobs#3 series refers only to the key style (thumb flat and handle) not to the part number. The other number I can see on the photo of your key, appears to be the British Patent number.
                                        Is there another part number on the chuck key? Also, Jacobs only appear to make keys with fractional inch spigots. The EMCO chuck has a 7.0mm hole. Has your key's spigot been turned down to fit?
                                        I have bodged something together from a rusty old unmarked key, just to get myself out of jail, but would like to find a better replacement.
                                        #273847
                                        Patrick McMahon 1
                                          @patrickmcmahon1
                                          Mike this key cam with the lathe when I picked it up. It doesn’t appear that the spigot has been turned down,they is a very small gap when inserted and the mesh is a little tight. I would say it’s not the original key for sure. Where it came from I just don’t know sorry.
                                          #273880
                                          mike T
                                            @miket56243
                                            Patrick, I have made do with an old unmarked key of more or less the right size. I needed to loctite a thin brass sleeve over the spigot to bring it to 7mm. I will try not to lose that one as well.
                                            Jason said he thought the Emco 3 jaw chucks were made by Rohm, I will have to follow up that lead.
