Polishing Acetal/Delrin and other plastics
Home Forums Materials Polishing Acetal/Delrin and other plastics
  • #435553
    Mike Donnerstag
      @mikedonnerstag
      Can anyone tell me the best way to polish plastics such as acetal once hand-turned in the lathe? I'm just turning some knobs for the Myford lathe.
      Many thanks,
      #29967
      Mike Donnerstag
        @mikedonnerstag
        #435557
        Ian Welford
          @ianwelford58739
          sand it from 180 grit through to 600 preferably with steam ate lubricated paper or ABRANET at slow speed in the lathe .Then wet sand with wet n dry upto about 1200 grit, follow with metal polish eg t cut if you want a really gloss finish.
          doesnt take long with each grit but wipe the work between grits with. damp paper towel to remove dust and possible grit parictles before using the next grit.
          #435561
          Mike Donnerstag
            @mikedonnerstag
            Many thanks Ian. Just the advice I needed. I’ll give it a try.
            #435570
              I use Micro-Mesh to finish Clear acrylic to a glass clear finish.
              As turned
              Polished inside and out
              Edited By JasonB on 01/11/2019 19:50:24
              #435576
              Ian P
                @ianp
                A lot of plastics like, acrylics (Perspex) and hard PVC are easy to polish, some like Acetal (Delrin) are more of a challenge and probably near impossible. I machine a lot of parts out of black Acetal and have not found any practical way of making even a very fine machining marks disappear.
                Jason, the ER collet in your pictures look a tad unusual in that the gaps between the tines look unequal, is it just an optical illusion?
                Ian P
                #435578
                  Ian, I think it is just teh angle of the photo, will check tomorrow and report back if it is something else.
                  I wonder if flame or chemical polishing would work one some of these plastics like it does with perspex
                  #435590
                  Alan Wood 4
                    @alanwood4
                    Slightly relevant but Polywatch is a compound for polishing scratches out of watch faces and is particularly good. It appears to fuse the material over the blemishes. Think it is on Amazon.
                    #435591
                    Ian P
                      @ianp
                      Acetal is quite a low friction slippery material a bit like PTFE, filing or abrading with even the finest wet and dry just leave a matt, white-ish surface. I'm not sure what temperature it melts at but I have never heard of it being flame polished.
                      Most, maybe its all, commercially manufactured Acetal components have visible signs of the machining so I have just assumed its not economic or possible to polish.
                      Ian P
                      #435593
                      Dalboy
                        @dalboy
                        Like Jason I use micro mesh to 12,000 grit sanded wet, also another method I have used is sand with wet and dry to 1200 grit and then apply burnishing cream. I get a good result with either method.
                        I have heard of people using T Cut to polish as well as brasso
                        This is one done with micro mesh
                        Edited By Derek Lane on 01/11/2019 20:57:38
                        Edited By Derek Lane on 01/11/2019 20:59:07
                        #435594
                        Cornish Jack
                          @cornishjack
                          Final gloss finish using Jeweller's rouge, perhaps? or, for cheapskates like me , toothpaste. Won't do for anything other than the very fine stage. Use to use it for watch glasses.
                          rgds
                          Bill
                          #435600
                          Paul Lousick
                            @paullousick59116
                            Toothpaste is a fine abrasive and often suggested for cleaning and polishing the outer glass on car head lights.
                            Paul.
                            #435601
                            Mick B1
                              @mickb1
                              I've been machining black and white acetal for years and it's never occurred to me to polish it – I've always thought the machined surfaces looked fine. If the tool's sharp and nicely stoned on the edge, you can get a very attractive finish.
                              Edited By Mick B1 on 01/11/2019 22:16:16
                              #435604
                              Sam Stones
                                @samstones42903
                                The two basic families of materials being discussed here are either crystalline or amorphous.
                                I'd like to suggest (although I haven't tried), that polishing items of crystalline materials, e.g. polyacetal, Nylon, polyethylene, polypropylene, etc. need to be deep frozen, or at least taken below their glass transition temperature.
                                I have machined (trued up) with some success, polyester (rubber) skate wheels directly from the freezer.
                                I also question, during the abrasion and polishing, if the surface of crystalline materials is being continually 'pulled apart', thus introducing (let me call it), a broken surface. Someone with good microscopy (and photographic) skills might like to intervene here.
                                Acrylic, and other amorphous materials on the other hand, are (generally) a breeze to polish.
                                Good luck,
                                Sam
                                #435607
                                Ian Johnson 1
                                  @ianjohnson1
                                  Try flame polishing with a Butane/Propane torch, just waft it carefully over the surface and it will leave a very pleasant looking satin/gloss finish. It also has the effect of making the surface more 'tactile', so knobs are ideal for this technique as all the edges are smoothed over and machining marks are erased. I've had good results with black Acetal but don't linger with the flame or it will melt, burn or bubble.
                                  Ian
                                  #435611
                                  Sam Stones
                                    @samstones42903
                                    And … don't sniff the smoke if you happen to overdo the flame treatment of polyacetal. You'll know why (and never forget) if you do.
                                    Other than this (after a bit of practice on something which doesn't matter), I'd go along with Ian's 'flame polishing'.
                                    It's also a useful (actually a commercial) technique for oxydising (oxidizing US) the surface of a crystalline polymer (plastic) prior to painting.
                                    Incidentally, there are many grades of amorphous plastics which are blended or otherwise modified with other materials, rendering them less polish-able (Ugh!)
                                    Sam
                                    Play safe
                                    #435614
                                    Ian Johnson 1
                                      @ianjohnson1
                                      Here's a mobile phone holder with a fluted screw I made a few months ago. It's made from black Acetal, and flame polished. Although some machining marks are visible because of the hand ground ball cutter, I think it looks pretty good, and it feels nice to hold, it's weird how Acetal feels different after flame polishing.
                                      Oh and like Sam says don't breath in the fumes if it starts burning, it's probably Phosgene or something equally horrid!
                                      Ian
                                      #435615
                                      Sam Stones
                                        @samstones42903
                                        Nice work Ian, and I trust you didn't mind my interjection re the fumes. I'm no chemist, but I think burning POM liberates formaldehyde.
                                        Compared with nylon and polypropylene, I much preferred machining p.acetal.
                                        Sam
                                        #435616
                                        Sam Stones
                                          @samstones42903
                                          I didn't have this picture loaded in my albums, hence this delayed follow up.
                                          This device for testing rotary switches features various uses of polyacetal. Black for bearings, and I think there's a slab of white with all those 'spikes' poking through. It may however have been high density polyethylene but I can't remember.
                                          Sam
                                          #435635
                                          Circlip
                                            @circlip
                                            For Acrylics, solvent vapour polishing works.
                                            Regards Ian.
                                            #435642
                                            Ian Welford
                                              @ianwelford58739
                                              I have the micromesh system and use it but for making a few knobs it seemed a bit OTT so hence the advice given. It shou”d have said STEARATE lubricated paper, fingers faster than brain as usual !
                                              Circlip, I have no ever heard of sovent vapour polishing, please elaborate on that one !
                                              regards Ian
                                              #435643
                                              Ian Welford
                                                @ianwelford58739
                                                oh my typing ! NEVER HEARD not no ever heard
                                                #435972
                                                Mike Donnerstag
                                                  @mikedonnerstag
                                                  Many thanks to everyone for all your help and advice.
                                                  Just for interest, I ended up putting a bar of 3/8" mild steel in the toolpost to use as a tool rest and hand turning the acetal with a 1/4" woodturning spindle gouge, with the bevel rubbing. The surface ended up polished, albeit very slightly ridged. I was happy with this – far better than the bare bolts I used to open the two side covers on the Myford lathe previously!
                                                  I will try the 'flame polishing' technique though, next time I turn acetal.
                                                  Once again, many thanks,
                                                Home Forums Materials Topics
