forming a thread on piano wire
Home › Forums › Materials › forming a thread on piano wire
  • #140861
    13Sigs
      @13sigs
      As to be expected I have had great difficulty in cutting a 3mm course thread onto a length of piano wire, I belief it is also called spring steel, with a presto hss circular hand split die. An expert has told me to forget trying to cut a thread on piano wire and if I must insist then to use a Gun Nose die because the die is more suitable for cutting very hard material. However from what I can make out, the only difference between the standard Presto split die and a Presto gun nose is that the gun nose is solid and pushes the swarf out in front of the die rather than allow it to gather within the cutting faces of the die. Can someone please advise.
      #29507
      13Sigs
        @13sigs
        #140865
        Sub Mandrel
          @submandrel
          Have you tried annealing the end of the rod and letting it cool as slowly as possible?
          13Sigs
            @13sigs
            Posted by Stub Mandrel on 16/01/2014 20:52:14:
            I did a test piece before cutting a thread but could not be sure of reversing the process and get the strength back. I tried a cherry red and quenced in water but the end of the rod broke off when under tension.  Hardening piano wire is a bit hit and miss and thought that cutting a thread would be the easier option.
            Edited By 13Sigs on 16/01/2014 21:01:29
            #140870
            Sub Mandrel
              @submandrel
              Piano wire is tricky stuff. If you are re-hardening the piano wire you also need to temper it to blue, simply quenching will leave it very brittle.
              Is there an alternative method you could use? Could you make a threaded collet to hold the piano wire or loctite it in place?.
              speelwerk
                @speelwerk
                Re-hardening and tempering will probably not bring the wire back to ist original condition, you will always get a (weak) part between the original and worked condition. You could try to temper the wire just enough to make it possible to cut the thread, and leave it that way. Niko.
                #140875
                Jeff Dayman
                  @jeffdayman43397
                  13sigs – If the OD you are starting with is 3 mm you might have better luck with drill rod / silver steel. The metallurgy is usually higher quality for drill rod and there is less internal stress than piano wire. Piano wire is drawn many times during manufacture and develops some nasty internal stresses and microstructure problems.
                  Annealed drill rod is much harder to die thread than free machining steel but far better than piano wire.
                  Good luck, JD
                  #140876
                  herbert punter
                    @herbertpunter99795
                    Any kind of heat treatment of piano wire will irreversibly change its properties.
                    The only way (IMHO) to make a thread in piano wire is spark erosion.
                    Bert
                    #140892
                    jason udall
                      @jasonudall57142
                      Or grinding. .
                      Piano wire is most certainly not homogeneous. .drawn many times and many of its properties are “work hardening” ( may be no such word but clearly such a behaviour )
                      Cutting /grinding /eroding through the outer layers will yield even without heat treatment a very different material behaviour.
                      #140893
                        An excellent point, Jason
                        [and Yes, "work hardening" is a perfectly valid term.]
                        … Interesting page here.
                        Speedy Builder5
                          @speedybuilder5
                          If you have had a go at cutting the threads on piano wire, I would suspect that your die is now too blunt for much else!
                          Bob H
                          #140927
                          JohnF
                            @johnf59703
                            13Sigs, It might be useful to know what you are making and why you are using piano wire, also how long is the thread?
                            One point about the HSS die, its worth noting that carbon steel can be and often is harder than HSS but not as tough but in this instance it might be worth trying, it might just cut better than HSS but don't expect miracles.
                            John.
                            #140975
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              It isn’t worth doing – the thread will be difficult to do and very weak no matter how you tackle it .
                              If a threaded end is absolutely essential on piano wire use a crimped or bonded ferrule nut .
                              MikeW
                              #140983
                              John McNamara
                                @johnmcnamara74883
                                Piano wire gets a most of its strength from the drawing process, you cannot successfully reharden it.
                                A while back I tried to do it myself buy heating to red then quenching the result was so brittle it shattered rather than broke into several pieces. I played around annealing it but the result was still brittle, as is confirmed by the following link.
                                I think attaching the wire by mechanical means is a better option.
                                john
                                #140992
                                Clive Hartland
                                  @clivehartland94829
                                  Looking at a Cycle wheel spoke it is obvious that the thread has been rolled on, I doubt that anyone other than a factory setup has this facility. Personally I would not try and thread spring wire and would go for a mechanical fix, using a flat on the wire to hold it secure.
                                  #141011
                                  Clive Hartland
                                    @clivehartland94829
                                    Well there you go, I am amazed that they still exist. But that is the answer rather than trying to cut a thread on carbon steel wire that does not want to be cut and retain a thread.
                                    #141024
                                    jason udall
                                      @jasonudall57142
                                      Thead rolled threads are much much tougher ( in the right material)
                                      than cut threads. .think forged..and if possible in piano wire..would yield an extremely durable result..
                                      Those bike rolls. ..mmm wonder what they would do on titanium spokes
                                      #141252
                                      Warwick Wilton
                                        @warwickwilton12363
                                        Hi all
                                        This is my first post so be gental. on the subject of tempering spring steel piano wire one of the tricks I have used was to heat the spring in moltan lead. this is close to the tempering temperature. and then quench in oil. this heats the part uniformly and the lead dosnot stick to the wire as it is not tined.
                                        Warwick.
                                        #141297
                                        Sub Mandrel
                                          @submandrel
                                          Hi Warwick,
                                          Welcome aboard – the big question is – can you tell us more about your motorbike?
                                          Warwick Wilton
                                            @warwickwilton12363
                                            Hi Neil
                                            Its an AJS 1927H3 side valve 350 touring
                                            Warwick
                                            sorry but I only get on this every second or third day
                                            #153189
                                            Tony Payn
                                              @tonypayn24819
                                              The thread rolling machine for spokes look interesting in the photos posted by John (Bogstandard2). They don't look too difficult to make either. How do they work and what would be needed to make one? I guess the three 'prongs' have hardened threads on them – are they geared together?
                                              A friend of mine has an Ariel Colt on which one wheel has over-long spokes, which consequently exit the hub almost tangentially to use up the spoke length before reaching the rim. He'll need to shorten the spokes and put new threads on the ends to correct it, that's why the spoke threading machine looks interesting.
                                              I guess the principle could be applied to other things as well. Sorry it's a bit off-topic, not much about models, but could be a good solution for this problem.
                                              Tony
                                              #153192
                                                ME ran an article on the 'Otto Di-Cycle' (IIRC) that had enough of an explanation of a home-brew thread roller to allow one to be built.
                                                  Lots of good information about thread rolling in general … here
                                                  … and for 12 seconds of poetry in motion, watch this
                                                  Edited By Michael Gilligan on 22/05/2014 23:33:37
                                                  #153216
                                                  Ady1
                                                    @ady1
                                                    3933 and 3935 have articles on diy thread rolling
                                                  Home › Forums › Materials › Topics
