A Little Light Relief – Mine’s Bigger Than Yours……………
Home › Forums › Materials › A Little Light Relief – Mine’s Bigger Than Yours……………
  • #72058
    Anonymous
      ……….unless you know different; swarf that is! I was in a bit of hurry to machine a 3″ bar of steel (EN3B I think) down to 1.5″ diameter this evening. Set the speed to 800rpm, depth of cut 0.1″ and feedrate 4 thou/rev. The swarf came off in loooooong tightly curled lengths, interspered with shorter lengths. The longest single length I could find is shown below; a bit over 11 feet. The ruler is a 600mm one.
      I also managed to burn my foot, and ruin another pair of socks, while operating the lathe; it takes real ‘genius’ to be that creative!
      #29441
      Anonymous
        #72059
        John Stevenson 1
          @johnstevenson1
          If you were in that much of a hurry then you should have been running at 1400 revs and 4mm cut.
          Medium feed [ don’t know what that is never looked at the book <g> ]
          John S.
          #72060
          Billy Mills
            @billymills
            I had a longer one than you but it went rusty and dropped off. How did you manage to do in the first pair of socks Andrew? is your lathe fitted with foot wheels? the Mystery deepens…..
            Happy Risk Assessments
            Billy.
            #72061
            Anonymous
              Posted by John Stevenson on 18/07/2011 23:10:34:
              John S.
              Steady on, I’ve only got a weeny lathe!
              #72062
              chris stephens
                @chrisstephens63393
                Hi Andrew,
                11 Feet, pathetic,
                A few years ago I was turning down some 80mm nylon, and got swarf that was around 150-175 YARDS long. I was going to take it to MEX at Sandown for a “guess the length of the swarf” competition on the SMEE stand. I haven’t given the exact length in case the idea gets resurrected another time.
                chriStephens
                EDIT I did it deliberately just for the fun of it, otherwise I would have taken  a heavier feed rate.
                Edited By chris stephens on 18/07/2011 23:57:26
                #72064
                Anonymous
                  Ah ha, I knew I’d be out-swarffed in short (long?) order.
                  Impressive, when I turn plastic the swarf always seems to wrap itself around the job in a big ball getting tighter and tighter, and generating heat, so I have to stop and clear it before it overheats and melts.
                  #72065
                  chris stephens
                    @chrisstephens63393
                    Hi Andrew,
                    Don’t feel bad about it, I was winding it up as I was going so that it did not get tangled.
                    chriStephens
                    #72066
                    Dave Tointon
                      @davetointon92281
                      I’d be inclined to increase the feed rate until the swarf chips into little blue pieces. much safer to clean up and a few of those down your boot will ruin a pair of socks very efficiently and give you a nasty burn as well!!!
                      Dave Tointon
                      #72083
                      Ian S C
                        @iansc
                        I did’nt measure my longest bit , it was 316 stainlessthat I was boring out to make a cup shaped piece for the hot end for one of my hot air engines. I was going a bit slow, about 500rpm, and taking 2 mm cuts, to bore a hole 1 3/4″ dia. Ian S C
                        #72085
                        NJH
                          @njh
                          You Guys need to get out more!
                          Cheers
                          Norman
                          Edited By NJH on 19/07/2011 12:21:32
                          #72088
                          chris stephens
                            @chrisstephens63393
                            What, and miss all the fun?
                            chriStephens
                            #72098
                            Anonymous
                              Posted by NJH on 19/07/2011 12:21:05:
                              Cheers
                              Norman
                              Quite the reverse actually! I seem to be out and about non-stop, so very little workshop time available, hence the rush that resulted in this thread.
                              Dave: Actually the loooong swarf was the exception rather than the rule. Most of it came off in lengths between 1″ and 10″. It seemed to alternate, one cut long, the next short. Presumably some subtle changes in the cutting parameters determine the length, but I’m blowed if I know what. It was one of the short purple bits of swarf that got into my shoe, and resulted in the ejection of said shoe about a millisecond later. Left a nice hole in the sock and a pretty pattern burnt into my foot.
                              According to my calculations I was removing 2.9 cubic inches per minute. Allowing 1hp per cubic inch per minute, I was on the limit, as I have a 3hp motor on my lathe. You could certainly hear the headstock gears taking the strain and slowing down slightly.
                              PS: The first pair of socks were ruined when I dropped a shovel load of swarf on my shoes when clearing up. There were so many little bits of sharp swarf embedded in the socks it was easier to throw them away.
                              #72101
                              Fil
                                @fil
                                Doesn’t everyone wear flared trousers to prevent the swarf-in-sock syndrome
                                #72104
                                Anonymous
                                  Yes, but as I’m getting older the trousers need to be flared at the waist line to allow for expansion, rather than at the trouser end.
                                  #72269
                                  Sub Mandrel
                                    @submandrel
                                    Chris,
                                    Your nylon swarf… perhaps you could teach the anglers how to make their own monofil.
                                  Home › Forums › Materials › Topics
