Help needed
Help needed
Home › Forums › General Questions › Help needed
  • #28462
    john steel 1
      @johnsteel1
      #575000
      john steel 1
        @johnsteel1
        I have a Warco Major milling machine and have just bought a set of chuck/collets from Lycorish for £55.29. My problem is when I put the dial gauge on the shaft it has a run out of half a thou very good, but when I move it down to the tool and the nut the gauge goes hay wire there is so much wobble I have cleaned the collet inserts and tried different tools which are brand new but it’s still the same what am I doing wrong Please help as I am new to milling.
        #575002
        Emgee
          @emgee
          If you made sure everything was clean before fitting the chuck to the spindle and you find run-out after that check the inside bore where the collet fits for runout, if that's as good as the spindle then the problem is with the collets.
          For what you paid you really can't expect anything too good in the way of accuracy, a half decent chuck would cost as much as your total purchase, you don't say what type of collets but a good ER25 collet will set you back around £15, even more if you want greater accuracy but that is a waste of money if the chuck has any runout.
          You may be able to return the collets and/or the lot for a refund.
          Emgee
          #575003
          Pete Rimmer
            @peterimmer30576
            If the collets are ER type you have to load the collet into the nut before you put them into the chuck. The face of the collet should sit at or very close to the face of the nut. If it doesn't, you probably don't have the collet fitted correctly.
            #575004
            john steel 1
              @johnsteel1
              Iycorish 9Pcs Er32 Spring Collets Set 2/4/6/8/10/12/16/18/20Mm + 1Pcs Mt3 M12 Er32 Collet Chuck Morse Taper Holder Collet Power Tool Set
              #575009
                Posted by Pete Rimmer on 11/12/2021 12:01:30:
                +1, well worth double checking.
                Not clicking ER collets into the chuck properly is a common beginner booby trap. How to do it isn't immediately obvious. You can guess how I know. Click on this ArcEuroTrade link for pictures and description.
                Fingers crossed that's the problem – easy fix.
                john steel 1
                  @johnsteel1
                  Thank you everone and Dave and Pete now I have the collets installed correctly there is a big improvement I have 20thou on the nut and 40thou on the tool is this OK could probably impove the tool with different ones
                  #575020
                  Speedy Builder5
                    @speedybuilder5
                    I hope you don't mean 20 – 40 thousandths of an inch !! a thousandth is 0.001". (a hair diameter is approx 0.003" to 0.007&quot.
                    Did you mean 0.0002" – 0.0004" ? ie: 2 – 4 ten thousandths of an inch perhaps ?
                    What are you using to measure, a DTI – have a look on the dial to see what the divisions are.
                    Bob
                    #575024
                      Don’t use a dti – use a dial gauge. One only indicates a change, the other actually measures the change.
                      #575029
                      Bill Phinn
                        @billphinn90025
                        Posted by not done it yet on 11/12/2021 14:23:18:
                        Unless you're using terminology in a way I'm unfamiliar with, I'm mystified by that claim.
                        Can you explain further?
                        #575033
                        Speedy Builder5
                          @speedybuilder5
                          Bill, Not done it yet is being a little precise and could be more helpful if he had explained the difference. I believe that a DTI is a finger gauge which Generally has a smaller movement that a Dial Gauge. That said, all the DTIs that I have seen are graduated and equally acceptable for measuring distance within their range.
                          For John's application, I would consider a DTI or Dial Gauge to be quite acceptable.
                          Bob
                          #575035
                          john steel 1
                            @johnsteel1
                            Sorry its a new dial gauge and I forgot its metric so its Fluctuating in thous 0.020 ether side of zero
                            #575037
                            john steel 1
                              @johnsteel1
                              With the new metric gauge its 0.20mm ether side of zero think the old gauge is no good
                              #575040
                              Bill Phinn
                                @billphinn90025
                                Posted by Speedy Builder5 on 11/12/2021 15:38:00:
                                Thanks for the confirmation, Bob.
                                Posted by john steel 1 on 11/12/2021 15:44:24:
                                Posted by john steel 1 on 11/12/2021 16:18:19:
                                0.020mm would be very acceptable, John; 0.2mm wouldn't.
                                #575055
                                John Baron
                                  @johnbaron31275
                                  Hi John, Guys,
                                  Check the insides of your collets very carefully !
                                  This is what most of mine were like. I used a Stanley knife blade and a stone to clean the swarf remains up. After that I could easily get a couple of tenths of a thou or better.
