.302 sounds wrong ! 2 sizes ! There is the one used on smaller vehicles .202 od and a larger one for BIG vehicles. Cant find one at the moment. Noel Ah yes ! Valve cap size is .306" X32 or.8mm for cars.
All the sizes are on the net. I get away with 5/16" x 32 tpi for the bigger ones when making motorcycle retaining nuts. The bespoke taps and dies are pricey for the odd nut.
I was thinking schrader valve not valve cap, so Yes jason your right ! That one is under size according to my schrader,michelin tool, .306". See edit. noel
Yep, that works fine to connect tyre inflators to run my stationary engines.
Wikipedia has info on Schrader valves. I have seen them used in compressed air regulators at 3000psi, and the cores look just like the short version and are the same size.
