It would be quite difficult to completely fill a small blind hole with epoxy. Two simple solutions are to drill out slightly and tap 6BA, if that is acceptable. Or alternatively drill out and tap much larger, say 2BA, and fill with a metal plug which can then be drilled and tapped 7BA.
A 2.05mm drill seems a bit small for 7BA, I'd use 2.1 or 2.15mm.
Edit: Must learn to type faster
Edited By Andrew Johnston on 01/09/2019 10:14:54
