Water pump dimensions
Home › Forums › General Questions › Water pump dimensions
  • #425219
    Garry Coles
      @garrycoles69390
      Hi, On my 2 in D & NY Traction Engine that i'm building I seem to have a problem with the water pump dimensions. That or I missing something. The water pump plunger is described as 3/8" bore with a stroke of 1/2" . When I look at the eccentric drawing, the offset from the centre of the drive shaft to the centre of the eccentric is shown as 1/2" To me that gives a stroke of 1". If that is right, then the plunger dimensions are wrong because at a 1" stroke the graphite packing on the plunger will come out of the bore. Of course, I could be completely wrong. So can any one help me please.
      Cheers Garry
      #26788
      Garry Coles
        @garrycoles69390
        #425241
        MichaelR
          @michaelr
          I think this drawing is the D&NY water pump, there seems to be a difference in the pump ram and pump bore dimensions, looks like the pump bore is the wrong size
          #425243
            Drawing says ream 3/8" and shows ram as 3/8".
            1" stroke does sound too much for that engine, he did use 1" stroke for the larger horizontal pump but 1/2" stroke eg 1/4" offset is more likely. By comparrison my 2" Fowler is 3/8" bore x 3/8" stroke.
            Edited By JasonB on 20/08/2019 20:41:07
            #425244
            Jeff Dayman
              @jeffdayman43397
              Jason did you mean 1/2" stroke from a 1/4" offset eccentric? I think 1/2" stroke would work for the shown pump body, but not 1" stroke.
              #425245
                Yes Jeff, altered it now
                #425249
                Jeff Dayman
                  @jeffdayman43397
                  yes
                  #425250
                    You only need to look at photos of other engines to see what the offset is, look at teh gear behind the eccentric, no way is it offset by 1/2"
                    #425265
                    Garry Coles
                      @garrycoles69390
                      Thanks for the replies.yes I will now go ahead with 1/4" offset on the eccentric. The eccentric dimensions on the drawing are wrong then. Thank god for that. I've fabricated the body, but did not start on the eccentric yet. smiley
                      #425288
                        This video shows the pump quite well, about half way through you can see that the ram lifts a little more than it's diameter so 1/2" stroke.
                        #425290
                        Garry Coles
                          @garrycoles69390
                          Thanks for the help Jason. yes
