Making the same mistake
Home › Forums › General Questions › Making the same mistake
  • #26776
    BOB BLACKSHAW 1
      @bobblackshaw1
      #424341
      BOB BLACKSHAW 1
        @bobblackshaw1
        I always make a cam and make the same mistake, its not so obvious until I've made it, then think it out the realize what I have done wrong.
        If I was making a hundred in a factory, not being a turner what a cockup I would of made.
        I have a 3.5mm offset, so I off set 3.5mm on the clock on a four jaw chuck, but that only gives me 1.75mm offset on the cam.
        Its logical to move 3.5mm and get 3.5mm, but it don't work out like that, sorry if this is a basic post.
        Bob.
        #424343
        Nick Clarke 3
          @nickclarke3
          I hear and share your pain!
          #424663
          mechman48
            @mechman48
            Try & set it 'double' on the clock just to see; otherwise set it up to run true with a live centre in the offset centre pop, adjust the jaws to nip it, set the clock to run true on a silver steel shaft with a male & female centres in either end & you should be on the mark.
            George.
