It might be worth going for a higher voltage to reduce the current, 120 Watt 24 Volt motors have been recommended on the Unimat Group, and there are plenty of 24V switch mode power supplies about now. I don't know the dimensions of the mill, and a lot of the listings on eBay don't give dimensions, but this 2400 RPM 150W motor looks pretty typical and is 68mm diameter and 108mm long if that is any help.
eBay Item
Brian
Edit: Don't bother looking, it is the same one Hollowpoint suggested
Edited By Brian G on 16/09/2019 21:42:22
