I recently started a thread 'Vertex or Arc' to help me choose a small vice. I have a preference for Vertex because I have some of their kit and am happy with it. In the end I decided to buy from Arc Euro Trade. I am glad I did, I bought a type 2 45mm vice and it is excellent. The springs that keep the pin block engaged in the rack make it very easy to use.
To release the vice you only need to turn the clamping screw about two turns then you tilt the key forwards to disengage the block from the rack, you can then slide the jaw fully open. To clamp the next job in the vice simply slide the jaw forwards up to the work piece and tighten the screw, the springs give it a ratchet action.
Regards, Michael
