Vice suggestions
Vice suggestions
Home › Forums › Workshop Tools and Tooling › Vice suggestions
  • #17937
    John Milligan
      @johnmilligan78347
      #217923
      John Milligan
        @johnmilligan78347
        I am gradually knitting out my new workspace, photos to be uploaded soon, and am after some advice on a milling vice. Bought a Centec 2A mill with the vertical head but machine has no milling vice. Table is quite small at 16" x 4 1/2" which is fine for me but the limiting factor is the table to head height, which is around 8" with the Clarkson Autolock fitted and smaller with the Jacobs chuck. So I need a quite low profile vice, question is as I only intend fairly light milling, will a machine drill vice be suitable once clamped down? Regards John
        #217929
        Speedy Builder5
          @speedybuilder5
          If you buy a vice with a rotary base plate, it takes up even more headroom!
          #217930
          Frances IoM
            @francesiom58905
            catch with most drill press vices is the jaw lift – maybe one of the precision vices from ArcEuro might be low enough – been happy with my one (+ a very small one that I mounted on a subplate) – MEW has had several designs for DIY vices including some low profile
            #217937
            colin hawes
              @colinhawes85982
              Low cost drill vices are not designed to take the side and lifting forces incurred when milling, you would be disappointed if you tried. The moving jaw on a machine vice needs long narrow guides. My photos show my homemade one that has been in use for more than eight years and it has features that you don't find on any other vice that I know of which are not obvious from the photo. Colin
              #217941
              David Clark 13
                @davidclark13
                The Arc Euro Trade or similar square vice will do what you want. Ground all over and very accurate. As a bonus, you can mount it on its side to lower headroom required.
                Edited By David Clark 1 on 27/12/2015 11:32:17
                #217958
                Michael Briggs
                  @michaelbriggs82422
                  I recently started a thread 'Vertex or Arc' to help me choose a small vice. I have a preference for Vertex because I have some of their kit and am happy with it. In the end I decided to buy from Arc Euro Trade. I am glad I did, I bought a type 2 45mm vice and it is excellent. The springs that keep the pin block engaged in the rack make it very easy to use.
                  To release the vice you only need to turn the clamping screw about two turns then you tilt the key forwards to disengage the block from the rack, you can then slide the jaw fully open. To clamp the next job in the vice simply slide the jaw forwards up to the work piece and tighten the screw, the springs give it a ratchet action.
                  Regards, Michael
                  #217959
                    No problem bying a vice with a swivel base, just take it off teh base to save height and just dig the swivel base out of the cupboard if you ever happen to need it.
                    J
                    #217977
                    Vic
                      @vic
                      Some drill vices aren't too bad. I bought a pair to mill a long part on my mill and they worked ok. A little fettling can improve them quite a bit if needed.
                      #217981
                      David Clark 13
                        @davidclark13
                        I have used Soba vices meant for a drill on a mill with no problems.
                        #217983
                        Bazyle
                          @bazyle
                          have a look at Harold Halls website for how to avoid needing a vice in the first place. You could also get a couple of Morse collets for the times you are desperate for headroom.
                          #217997
                          John Milligan
                            @johnmilligan78347
                            Thanks for all the advice guys, will study in detail over the holiday period! John
                            #218013
                            Frances IoM
                              @francesiom58905
                              the catch with all low headroom mills is that change of the tool may well require moving work off its register tho DRO makes this somewhat less of a problem – maybe ER25 (or similar) collets might be best in this regard
                              #218024
                              Vic
                                @vic
                                Posted by David Clark 1 on 27/12/2015 14:57:22:
                                Yes, I believe the two I bought were Soba. Low profile but quite solid for a drill vice.
                                Similar to this:
                                http://www.chronos.ltd.uk/acatalog/info%5f110152%2ehtml
                                Edited By Vic on 27/12/2015 18:30:10
                                #218166
                                John Reese
                                  @johnreese12848
                                  I suggest a toolmakers screwless vise (USA spelling) for your size machine. Just make sure there are grooves on both sides for clamping it down. They are made in sizes from 2" jaw size and larger.
                                  #220149
                                  John Milligan
                                    @johnmilligan78347
                                    Just received the toolmakers vice from Chronos and am well impressed so thanks for the pointers, now to put it all into action!
