capacitor or motor problem???
Home Forums Manual machine tools capacitor or motor problem???
  • #12950
    jimmy b
      @jimmyb
      #294586
      jimmy b
        @jimmyb
        My lathe, (chester crusader), has been running fine for a few years, I had to change both the start and run capacitors a few years ago as they were making some rather odd noises. I was running it yesterday for a few hours and noticed that its starting bit slower than normal.
        I've ran the motor with no belts connected and the same thing happens. As the motor takes a long time to stop, I assume the bearings are not the cause.
        Is it worth changing the start capacitor, or am I barking up the wrong tree??
        Cheers Jim
        #294587
        John Rudd
          @johnrudd16576
          Changing the start cap first is the easiest and cheapest way to rule it out.
          It may pay to buy a better quality cap from a reputable source for longevity……,
          #294590
          Gray62
            @gray62
            As well as the start cap, I would check the condition of the centrifugal switch inside the motor, I had one a while back that despite being able to hear it operating, the contacts were not in a good state and also a dry solder joint on one connection.
            #294612
            jimmy b
              @jimmyb
              Thank you,
              I've ordered a new start cap.
              We'll see what happensyes
              #294615
              John Rudd
                @johnrudd16576
                It could be the start of a turning point…..
                I'll get me coat….,
                #294617
                jimmy b
                  @jimmyb
                  At times like this, I wish I'd not placed the lathe right against the wall…….
                  #295501
                  jimmy b
                    @jimmyb
                    Got the new capacitor,.
                    The old one had leaked quite a bit!
                    Changed it and I'm not convinced its a fast starting as it used to be…
                    I may have to look in to a variable speed set up next…………….
