Greyson 3 1/2 Lathe
Greyson 3 1/2 Lathe
Home › Forums › Manual machine tools › Greyson 3 1/2 Lathe
  • #111033
    John 77
      @john77
      I have aquired a Greyson 3 1/2 Lathe which I am restoring. It had been dismanteled by the previous owner. I have a problem with the tailstock it is in two parts bottem and top there 3 holes one tapped on the top half at the front with a left hand thread wich I asume is to offset the tophalf one hole oppisite in the rear with no thread and one hole in the handle end with no thread and countersunk hole in the bottem of top half threaded. The bits that fit these holes are missing.Can any one advise me what parts are missing.
      John 77
        @john77
        Tail stock information
        #111048
        Brian Wood
          @brianwood45127
          Hello John,
          I can't help you directly, but others might if you put some pictures on the post so that they can see for themselves, your description is confusing. They were made in fair numbers so someone should know.
          Brian
          #111049
          Keith Long
            @keithlong89920
            Hi John
            Another place worth looking is the www. lathes.co.uk website run by Tony Griffiths. There is a lot of info on there about Greyson lathes as well as the variants that were sold rebadged – Randa for example. Some of the pictures of the various models might help with the overall re-assembly as well as your specific question.
            Keith
            #111051
            Takeaway
              @takeaway
              Hello John – Sorry cannot help with your question but would like to tell you that I acquired a 3.5" Grayson many years ago and because I had access to a range of machine tools at the time was able to carry out a full re-condition. End result was a Grayson that was probably more accurate than when it was new. I found it to be a great little lathe and can still hear the slap of the leather drive belt from the wall mounted lay shaft.
              Sadly it had to go (divorce). For the life of me and after some 30 odd years, I cannot remember what the tailstock looked like but I wish you well with the refurb., I'm sure you will not be disappointed with your "new" lathe.
              ATB
              Stuart
              #111080
              _Paul_
                @_paul_
                This is my Grayson which has a modified tailstock it's also buried at the back of the workshop so will take me a while to get at it:
                My Grayson
                If theyre any good to you heres some pics of other Grayson tailstocks from my picture collection:
                Grayson Tailstock 1
                Grayson Tailstock 2
                Grayson Tailstock 3
                Paul
                #111082
                Mike Wainwright
                  @mikewainwright87512
                  i have the same lathe and it is in pieces on the floor of my shed so if the need any pictures please let me know. I also have an article of that can be done to this lathe. This was sent to me by one of the people on this forum and I would be happy to pass it on if you want.
                  #111120
                  Sub Mandrel
                    @submandrel
                    Paul
                    The pictures show a pin in the hole at the back of the tailstock -the one I assume (in the other thread) to be for locating the tailstock centrally.
                    Similarly I see a pin at the back of the orange one, and an adjusting screw in teh third picture.
