BCA Miller grease nipples and grease guns?
Home Forums Beginners questions BCA Miller grease nipples and grease guns?
  • #509017
    Arthur Moore
      @arthurmoore87122
      Hi everyone, I have been given a BCA miller which has round headed grease nipples about 5.8mm across.
      Will something like the Hilka grease gun fit these nipples, or what do I need?
      https://hilka.co.uk/manual-grease-gun-set-84800120.html
      I do not want grease to leak all over the machine when I try to use the gun on a nipple for the first time.
      Thanks for your help, Arthur
      #10549
      Arthur Moore
        @arthurmoore87122
        #509024
          Put a cloth down as a precaution? Might even need to be oiled, not greased?
          #509030
          Arthur Moore
            @arthurmoore87122
            Yes – I wondered if they were oil nipples, but I unscrewed one and it is definitely full of grease.
            I will definitely put down some cloth, but hope that someone on the site would have found what type of gun best fitted these antique nipples so that not too much goes to waste.
            I also wondered if I would be better unscrewing each nipple and putting the end of the grease gun in the hole?
            #509035
            Phil P
              @philp
              I would be using oil and not grease on your BCA, I have Boley & Leinen which is its predecessor and only use oil on that one.
              Phil
              #509043
              Arthur Moore
                @arthurmoore87122
                Thanks Phil,
                Some of the Boley millers seem to have the same round head grease nipples as mine and some have oil pots. Has yours the round headed grease nipples? If so, are you just squirting oil in the nipple and did you clean out the grease, or was it always oil lubricated?
                I am not too worried about the table and vertical slide given the small amount of machining that I need to do.
                The thing that has to be right is the main spindle with a grease nipple half way up the column and a horizontal feed from the nipple to the spindle. As I use small diameter mills, Tony at LathesCo said I should consider increasing the diameter of the pulley on the motor to increase the rotational speed, but I would not like to do that without ensuring the spindle was properly lubricated.
                #509044
                Arthur Moore
                  @arthurmoore87122
                  I thought some photos would help:
                  The BCA Miller
                  Grease nipple on front of main spindle
                  Grease nipple on front of spindle
                  #509086
                    Welcome, Arthur
                    Nice to see the original cotton belt there !
                    The recommended lubrication was:
                    Main Spindle : 2 Nipples : Oil : Shell Vitrea 37
                    Slides and Rotary Table : Nipples : Grease : Shell Alvania 2
                    Rotary Table Worm : Oil : Shell Vitrea 37
                      Here’s a useful list of substitutes for the discontinued Vitrea Oils: **LINK**
                      https://www.lubefinder.com/range/shell-vitrea.html
                      Nigel Graham 2
                        @nigelgraham2
                        Thank you for this question and answers – I have the same machine and was wondering what lubricants it needs.
                        #509091
                        Phil P
                          @philp
                          Here is a shot of mine, it has oiler cups where the outer sleeve has a knurled ring that you rotate half a turn to reveal the hole in the top.
                          Phil
                          #509092
                            That’s a beauty, Phil yes
                            Arthur Moore
                              @arthurmoore87122
                              Thanks for all the useful information. Just what I needed
                              Phil – your machine is in lovely condition. Did you fully refurbish it and did you use Tony's book and was it useful?
                              Arthur
