What did you do today (2015)
Home › Forums › The Tea Room › What did you do today (2015)
Viewing 25 posts - 2,276 through 2,300 (of 3,154 total)
  • #202697
    Nick_G
      @nick_g
      Posted by JasonB on 31/08/2015 17:26:11:
      Over the weekend I have completed the base for my 2/3rd scale Tidman engine and also got the bearing keeps and oil pots done.
      Nice. smiley
      Looks like it's going to be a bit of a beast that one Jason. Are you going to need a bigger compressor.? wink
      Nick
      #202698
      Nick_G
        @nick_g
        Posted by Windy on 31/08/2015 16:58:15:
        Nearly finished the new prop to replace the broken 130mph one just to polish it and a spare one is nearly finished.
        Oh for a CNC milling machine.
        Paul
        Excellent work by the look of it.
        What sort or RPM (in the water) will that be doing Paul.?
        Nick
        #202725
        Windy
          @windy30762
          Nick
          It's not easy getting the curvature the same as the broken prop but will see at the end of September if I cannot give it a try next weekend.
          As a rough guess when at peak speed on the water 11000rpm when airborne or free running 15000rpm plus.
          Paul
          #202876
          Boiler Bri
            @boilerbri
            For my birthday last May my eldest bought me a ride on Waverely and to day was the day.
            #202909
            Raymond Sanderson 2
              @raymondsanderson2
              Posted by Nick_G on 31/08/2015 02:06:43:
              Did some machining and my mate came round on this :-
              So I had a little play on it. smiley
              Nick
              Lucky basket.
              When at Technical collage it was my turn to go for lunches, my scooter stuck in the corner of the loading bay with a seniors Norton easier to get out. I had asked him to move his nicely as we shared the area and often rode home along the same highway. Next thing I heard was here catch!!! I heard the tinkling of keys said thanks as I caught them and started moving his brand new bike (4 weeks old) he yelled out no take it to get the lunches it'll be quicker!!! smile o I was dumb founded. There sat my little Honda 90 step through looking like a Corgi toy beside his Norton. He came helped me back it out onto the street loading bay was littered with steel and such. I had ridden a mates 750 Four so a bigger bike was no problem me being a weed.
              3/4hr latter I returned with angel 2 look on my face.
              Needless to say I sat quietly in class the rest of the day. LOL
              #202910
              Raymond Sanderson 2
                @raymondsanderson2
                Posted by Anthony Knights on 28/08/2015 23:10:24:
                files1.jpgFed up with searching for a specific file ,I finally got round to doing something about it.
                files2.jpgSo I made this
                files3.jpgFinished it today. My files are now all filed.
                Brilliant idea I am about to make something similar for the selection of auger bits I have now will have to cut some more tube for the files thanks idea stolen.yes
                #202911
                Raymond Sanderson 2
                  @raymondsanderson2
                  Posted by Nicholas Farr on 23/08/2015 16:12:40:
                  Hi, well today I had a bit of a spontaneous spending spree in Aldi's. Just went in to see if there was anything worth getting and spotted an angle grinder stand for 115 and 125mm angle grinders, for £12.99. The box felt reasonable heavy, so I thought why not get one and see. Moved along a bit and saw packets of grinding/cutting and flap wheel discs for £3.99 each, but they were all 125mm ones and I don't have a grinder that size, but hey next to them was a 125mm angle grinder with an integral speed regulator for £19.99. Ended up buying the grinder the stand, one pack of four flap discs and one pack of eleven thin cutting discs for a total of £40.96.
                  Got the stand out of the box and the most part is made of die cast, but the base is cast iron. It was simple enough to assemble, although there were no real instructions for assembly.
                  Just one Issue so far is that the bottom adjusting screw the keeps the grinder vertical to the work, does not make a good contact on the grinder, although it says it is suitable for their own grinder (just maybe not for this model)
                  As can be seen in the above photo, the bottom screw has been skewed downward as there is no positive location for the plastic pad to bear onto. Might fit my 115mm grinders OK, will have to see, but maybe will have to make a bracket of some sort to fit this one.
                  This stand will probably be OK for what it is intended for, but I doubt it will stand up to viigorus or heavy work.
                  Regards Nick.
                  P.S. sorry about the second photo being on its side, but it just does not want to do anything else.
                  Edited By Nicholas Farr on 23/08/2015 16:15:10
                  Hi Nicholas I bought the cut off bit some time ago to use on my grinder a Hitachi no way could it fit without mass work to be done. Latter bought the Aldi grinder as it has VS very useful that is, BUT here in AU we have found the need to make an arbour to match the disc size we can get annoying yep even though Aldi sell disc about the same time they also do not fit the arbour on the machine.
                  #202912
                  Raymond Sanderson 2
                    @raymondsanderson2
                    The last few weeks have been flat out like a Lizard drinking.
                    Setting up a machining job for an adaptor step down from 30×3.4 to 1"x10, rough turning 2 English Oak Motar & pestle on the wood lathe. Race over 1hr each way to see MiL who is in nursing home only to find due to a serious flu epidemic the place is in lock down NO visitors. Being we were heading away for a week to QLD to meet up with a cousin from Petersbourgh I had not seen in 55yrs didn't wan to pass on anything.
                    13hr drive from Sydney to Toowoomba QLD and first phone call came 250k away from home and didn't stop till we returned just prior arriving at nursing home a week latter regarding MiL's health and hospitalisation. Had top 4 days with cousin and his wife. Return journey via coast route saw me find out how slack some tradesman can be when the disabled shower seat newly fitted parted company from the wall with me on it. Yes there are photos No not posting the ones with me still on the seat and floor.
                    Idiot had used 4 light gauge screws into plugs into tiles and plaster board NOT 1/4" min stainless bolts into brick wall.
                    Final call from SiL please get home ASAP MiL not good, poor dear only lasted a further 5 days funeral is tomorrow Thursday EST. Still at 91 she did far better than she though she would being her 3 sisters and brother and hubby had passed away many yrs prior.
                    The 2 weks at home since arriving back have been a blur organising all sorts LOML and her sis, me doing up the DVD for funeral.
                    Time in the workshop resulted in a repair to a 2 draw tool box of quality well it was supposed to be. The spot welds have given way allowing the draw runners to part company as you opened the draw, riveted it back together 4 in in all. These draws store my wood turning chucks etc.
                    Maybe Friday or next week I can return to finishing off projects started. 4 weeks or is that 5 weeks ago smile
                    PS Finding my MEW mag had the plastic cover torn and rain soaked to the point of pages are stuck together after drying has me devil at our new postie.
                    #202926
                      Hi Ray,
                      Sorry to hear about your mother in law, at least she had a decent innings.
                      Which issue of MEW bit the dirt? Let me know and we'll send a replacement out.
                      Edited By Neil Wyatt on 02/09/2015 09:07:50
                      #202927
                      NJH
                        @njh
                        Good grief Raymond – I think you need a holiday!
                        We've just had our No.2 son with us here in sunny Devon for 5 weeks – he lives in Melbourne. I just can't get my head around the distances between places you have out there. Hope things calm down a bit for you soon.
                        Norman
                        #202929
                        Jon Gibbs
                          @jongibbs59756
                          Posted by Swarf, Mostly! on 31/08/2015 16:06:51:
                          Posted by Frances IoM on 31/08/2015 12:10:52:
                          Later society was prob IEE as the IRE merged into it (the IEE is now IEETE but still with headquarters in Savoy House – 1st home of BBC and at one time having the only non-red phone box in front of it – AM was common grade – MIEE generally required a degree (or two) + some experience at a higher level in industry – gave CEng status
                          Edited By Frances IoM on 31/08/2015 12:13:49
                          It was really quite gentlemanly of the IEE to describe it as a merger. I'd describe it rather as a benign rescue takeover. The IEE had succeeded at recruiting University leavers and their distribution of membership numbers vs age was fairly flat. The corresponding graph for the IERE was a hump at the older end, inexorably moving to the right at a rate of 12 months per year – we were doomed, I tell you, doomed!!!
                          Quite nice to hear that the IEE did something vaguely useful!
                          I've been a member for 33 years and all they seemed to do, at least before becoming the IET, was erect either statues of, or plaques to the memory of, Michael Faraday!
                          Jon
                          #202943
                          Swarf, Mostly!
                            @swarfmostly
                            Posted by Jon Gibbs on 02/09/2015 09:18:53:
                            Jon
                            Hi there, Jon,
                            Before I moved to sunny Hampshire, I did a stint on my local IEE Area committee. The committee members worked hard to arrange a programme of interesting lectures for the members. Nowadays I try to get to the monthly lectures arranged by the Solent Retired Members Section. That programme, too, is varied and interesting. Maybe you should have a look at the lecture programme in your area?
                            Best regards,
                            Swarf, Mostly!
                            #202948
                            KWIL
                              @kwil
                              I agree with the above regarding the IEE, (now IET), you must take part, you can also visit other profession's branch meetings, for instance, I attended a meeting at Boscombe Down organised by the Local Branch of the RAeS.
                              #202950
                              Jon Gibbs
                                @jongibbs59756
                                Posted by Swarf, Mostly! on 02/09/2015 11:21:20:
                                I take my hat off to you for volunteering.
                                Although I've attended one lecture over the years as I'm still working I always seem to have better things to do – like being in the workshop wink
                                The IET do pretty well out of me though – I keep paying my dues even though I really don't feel I get much in return. I'm also a Senior member of the IEEE although that is significantly better value IMHO.
                                Jon
                                #202952
                                Another JohnS
                                  @anotherjohns
                                  Finishing up the "improvements" on our little caravan, after a trip to a local Ontarip Provincial Park – Algonquin Park.
                                  Normans' comment to Raymond prompted this – Algonquin Park is about 1/3 the size of Wales. The last 40 or so km to the campground were over dirt roads, and the compartments over the wheel wells were covered with a fine grit. So, out comes the silicone caulking, and the job continues.
                                  Model Engineering Content: Flipped through my photocopies of the DB23 locomotive construction notes photocopied a while ago from the Dutch Model Engineering magazine. Beautiful locomotive, and fantastic design, beautiful views over Grand Lake, interrupted only by a flock of Merganzers feeding, and the odd Loon call… (smile)
                                  #202955
                                  Bazyle
                                    @bazyle
                                    Posted by NJH on 02/09/2015 09:16:34:
                                    Norman
                                    Devon, August, sunny – that must be some Australian Devon then sad
                                    Norman have you been to the museum at Swan Hill during any visits to son? Well worth the trip.
                                    #202959
                                    NJH
                                      @njh
                                      Still nice and sunny in Devon today Bazyle ! 😎
                                      Trips to Australia – sadly not. It's not that I don't like flying – I flew gliders for some years – but the prospect of flying to Australia is beyond endurance. I wouldn't want to sit in my own armchair for that long!
                                      Norman
                                      #202965
                                      Steve Papworth
                                        @stevepapworth83993
                                        Where in Devon, Norman?
                                        It's sunny here too – just north of Okehampton. Actually, it's pretty hot, as I have been cutting the grass, which seems to have grown a foot during my holidays.
                                        #202977
                                        Bazyle
                                          @bazyle
                                          *&%$£ and other bad words. bank holiday weekend – wet dull and gloomy only just managed to get the grass cut but it had hardly grown in a fortnight 'cos it thought it was winter already. Week off in early August gloomy dull and wet. Booked Friday week off so look out for hailstorms.
                                          #202987
                                          Anonymous
                                            Been slogging away over a hot Bridgeport in the workshop all day, for work. For some light relief I picked all the blueberries in the garden this evening:
                                            Best crop I've ever had; not bad for two plants. Blueberry muffins here we come!
                                            #203005
                                              You did better than me Andrew, virtually nothing from the Blueberry, will have to make do with blackberry muffins but I did have the first of the plumbs with custard last nightsmile
                                              #203010
                                              martin perman 1
                                                @martinperman1
                                                Gentlemen,
                                                Since monday ive been displaying my Lister F type at the Geat Dorset Steam Fair, back home next monday. Very cold at night but the weather hasnt been to bad.
                                                Martin P
                                                #203012
                                                Raymond Sanderson 2
                                                  @raymondsanderson2
                                                  Posted by Neil Wyatt on 02/09/2015 09:07:16:
                                                  Hi Ray,
                                                  Many thanks Neil many thanks it was/is No 232.
                                                  Yes Neil she did a woman who had been through much in her life being born 1924 and during WWII and the invasion of her home land Toscha (Torza) forced to become a Yugolsave forced to leave her home behind and head for Poland. To marry and again leave to foreign nation.
                                                  #203013
                                                  Raymond Sanderson 2
                                                    @raymondsanderson2
                                                    Norman
                                                    Its my LOML who needs it more than me Norman yet like these things the legal side is now to be settled the sooner thats done the better. Then maybe a holiday.
                                                    Its scary but the highways between capitals are not congested and if a clean run, no road works or accidents you can do Sydney to Brisbane in 11/12 hrs straight close enough to 1000k or Sydney Melb 900 10/11hrs. Sydney SA in 14/16hrs depending on the route. WA takes 3 days, NT/Dawrin a week.
                                                    Victoria small as it is you can drive round in a day.
                                                    Yet there is a property in QLD takes 3 days to drive from one side to the other.
                                                    #203017
                                                      Thanks Ray, I've passed your details on to Kate, she should get the new copy sent out to you soon.
