What did you do today (2015)
Home › Forums › The Tea Room › What did you do today (2015)
Viewing 25 posts - 2,251 through 2,275 (of 3,154 total)
  • #202251
      Posted by Ketan Swali on 27/08/2015 16:53:55:
      ARC doesn't put such stickers on small parcels because past experience says that if delivery person or anyone in process got out of wrong side of bed, the said parcel gets used like a football if marked 'Fragile'.
      That reminds me of my Christmas Post job … final year at school.
      Working in the Sorting Office.
      One of the regular staff [not a student] grabs a large envelope bearing prominent labels:
      "Photographs Do Not Bend" reads he, joyously folding the envelope in half … "Yes they ######-well do!"
      Anthony Knights
        @anthonyknights16741
        files1.jpgFed up with searching for a specific file ,I finally got round to doing something about it.
        files2.jpgSo I made this
        files3.jpgFinished it today. My files are now all filed.
        #202365
        Martin W
          @martinw
          Anthony
          Great idea and it looks good as well, but is that a file I see on the bench with no home to go to wink 2.
          Cheers
          Martin
          #202381
          HughE
            @hughe
            Retired yesterday. Looking forward getting back to the workshop. One blocker HI has produced list of things to be done. Might as well go back to work !
            #202391
            Anthony Knights
              Hi there HughE. I've been retired for 5 years and if you are like me you will find there is that much stuff to do at home, you will wonder how you ever found time to go to work.
              #202392
              Anthony Knights
                Martin W. The "homeless" file you see is the de-burring file which usually sits between the lathe and the mini mill/drill.
                #202400
                David Clark 13
                  @davidclark13
                  My postman is a forger. He must be as I am never asked to sign for recorded delivery, either letters through the box or even if he has to knock for me to open the door.
                  #202412
                  Bazyle
                    @bazyle
                    My postie struggles past soggy bushes and under snow laden branches to deliver me…….threatening letters from the BBC. I don't see why I should tell them over and over again I don't have a TV here. I often have to dry the letters out before I can use them to light the fire.
                    #202416
                    Clive Hartland
                      @clivehartland94829
                      I believe someone has successfully sued the organisation that sends these letters, do it and see what you can get.
                      You need the letters as evidence because basically they are trying to claim money under false pretences.
                      #202440
                      Roger Williams 2
                        @rogerwilliams2
                        Wandered into our local railway workshop, and there was the A4 , 60009. Very unusual. Turns out it broke down at Newton Abbot, and ended up here with badly knackered bearing (l/h of the 3 I think). Causing a lot of trouble by all accounts because its supposedly hasnt been long in for repair at Crewe. I was told it is supposed to be pulling the royal train in Scotland in a couple of weeks, so the owner is not happy. The offendscf1543.jpgding wheel set is on the right of picture. Big job !!..
                        #202516
                        Howi
                          @howi
                          Finally got round to taking some photos of two recent projects, first is a tapping tool for small delicate taps from some free plans found on the internet, just had to change the dimensions to metric.
                          Second project was to make some more tool holders for my QTP for AMA210VG lathe, I have enough material for about 12, this one is the first and my first time cutting a dovetail. The commercial one is on the left, my copy on the right – only 11 more to go crook
                          #202520
                          Frances IoM
                            @francesiom58905
                            ArcEuro sell a similar tapping aid which I’ve found very useful as the base has T-slots so is easy to fit a small holding jig for repetive small tapping jobs – I added a small collar + fixing screw between the handle and the top bar – makes replacing taps very easy without the chuck crashing down on the work – also provides a simple depth stop for blind taps – pity only works upto 5mm metric (6mm on some softer material) tho I did have to loctite the chuck to the rod (breakable seal tho)
                            #202568
                              Just got back from my Dad's. I've got a few boat RC pics to share tomorrow including his HMS Matabele (about 50 years old and showing her age!)and my own Miss Britain III on maiden voyyage which was an absolute treat. The multi-step hull paned beautifully, very stable and it looked really realistic at a decent speed with a 'scale' wash.
                              In the meantime a bit of family history – I now have a family tree back to 1570!
                              The lad second from the left is my paternal grandfather, and the lady and gentlemen at right are two of my great-grandparents. As you can see several of them were in the Sally Army band!
                              This is where my Grandad was when Dad was born (confirmed by birth certificate):
                              Now a couple of pics of my dad float testing the hull of his Warspite, these would be about 14 years ago:
                              His comment is 'that was when I discovered you can't use acrylic over oil-based paints' – at leats not the mix he chose!
                              Edited By Neil Wyatt on 30/08/2015 22:21:40
                              #202572
                              Nick_G
                                @nick_g
                                Did some machining and my mate came round on this :-
                                So I had a little play on it. smiley
                                Nick
                                #202577
                                mick70
                                  @mick70
                                  Posted by Howard Winwood on 30/08/2015 13:33:15:
                                  Got same tool holders from arc .
                                  Would like to make some as learning project on mill at club.
                                  What angle dovetail cutter did you use?
                                  Thanks.
                                  #202592
                                  Howi
                                    @howi
                                    Hi
                                    The dovetail cutter is 60 degrees, the small one from arc, used 30mm square as could not get 1x 1.25
                                    .regards
                                    H
                                    #202623
                                      Few more pics from yesterday.
                                      Dad's very venerable (nearly fifty year old) HMS Matabele in 1:48:
                                      A neat little steam launch that gave the owner a bit of bother 'its been running fine on the bench!' but finally ran nicely:
                                      A nice little freighter:
                                      My model of Hubert Scott Paine's Miss Britain III:
                                      Finally, here's one from the fambly album I finally got a scan of./ Apparently this was for Barry Carnival, the kids are not relatives!
                                      #202626
                                        Postcript -you can see my grampy was an Associate Member of the British Institute of Radio Engineers – I found his certificate form 1946, in the mid-fifties. I discovered that he also became an associate member of one of the engineering societies, but I have already forgotten which one!
                                        I wish that van was still in the family, I remember the 'horns' very well – they used to be hired out every time there was and election in Barry or a fete in Romilly Park.
                                        Frances IoM
                                          @francesiom58905
                                          Later society was prob IEE as the IRE merged into it (the IEE is now IEETE but still with headquarters in Savoy House – 1st home of BBC and at one time having the only non-red phone box in front of it – AM was common grade – MIEE generally required a degree (or two) + some experience at a higher level in industry – gave CEng status
                                          Edited By Frances IoM on 31/08/2015 12:13:49
                                          #202639
                                            No, it wasn't an 'electrical one', which surprised me – It might have been IMechE. He didn't have a degree, although apparently they called him 'Professor' when he taught at Cranwell.
                                            Ed Duffner
                                              @edduffner79357
                                              Some lovely models there Neil.
                                              I have the Sirmar BYMS hull and all fittings (my dad served on one from `43-`46) but haven't made a start on it yet.
                                              Ed.
                                              #202653
                                              mick70
                                                @mick70
                                                Posted by Howard Winwood on 31/08/2015 09:12:44:
                                                HiÂ
                                                The dovetail cutter is 60 degrees, the small one from arc, used 30mm square as could not get 1x 1.25Â
                                                .regards
                                                H
                                                cheers must be my measuring using cheap angle gauge was getting 62 deg.
                                                #202667
                                                Swarf, Mostly!
                                                  @swarfmostly
                                                  Posted by Frances IoM on 31/08/2015 12:10:52:
                                                  It was really quite gentlemanly of the IEE to describe it as a merger. I'd describe it rather as a benign rescue takeover. The IEE had succeeded at recruiting University leavers and their distribution of membership numbers vs age was fairly flat. The corresponding graph for the IERE was a hump at the older end, inexorably moving to the right at a rate of 12 months per year – we were doomed, I tell you, doomed!!!
                                                  Best regards,
                                                  Swarf, Mostly!
                                                  #202675
                                                  Windy
                                                    @windy30762
                                                    Nearly finished the new prop to replace the broken 130mph one just to polish it and a spare one is nearly finished.
                                                    Oh for a CNC milling machine.
                                                    As I'm always trying to find more Horsepower might try the following at least the stuff out of the backend will be good for the garden.
                                                    Was hoping to have a blast with the steamer next weekend but a minor health problem might curtail it as have been told to keep out of the workshop and rest my legs indecision.
                                                    Paul
                                                    Edited By Windy on 31/08/2015 17:00:55
                                                    #202680
                                                      Over the weekend I have completed the base for my 2/3rd scale Tidman engine and also got the bearing keeps and oil pots done.
