Upgrade from SC3 lathe
Home › Forums › Workshop Tools and Tooling › Upgrade from SC3 lathe
Viewing 16 posts - 51 through 66 (of 66 total)
  • #380922
    ega
      @ega
      Posted by Joseph Noci 1 on 16/11/2018 14:56:20:.devil
      But a very neat gadget I did purchase is the ER collet tailstock turret – I use that so very regularly that I wonder how I did without it before. It does take some care though – not snagging your hand or side of the head on that porcupine to the left of you…
      Is this a turret with multiple ER chucks? Can you perhaps point to or post a photo of this interesting-sounding accessory?
      #380923
        I would have thought that could be done with any turret that has parallel tooling holes, just cut down some plain shank ER collets to the right length and away you go.
        You could do similar to Joe's turret on your SC4 with one of these and some parallel shank ER collet chucks, bit like this one on Neil's SC4
        Edited By JasonB on 17/11/2018 07:39:30
        #380930
        Joseph Noci 1
          @josephnoci1
          .ega, it looks like this:
          Joe
          #380932
          Joseph Noci 1
            @josephnoci1
            I had my head so far in the chucks story, I did not even realise how good an advert I posted for Vero Electronics..The ruler was given to me by a Vero rep. at least 20 years ago and just gets used around the shop now- Do I need to do something about this? I can edit the text out and re-post if mods will first delete that post…
            Sorry about that.
            Joe
            #380941
              I wouldn't worry about promoting Vero, unless you are also worried about plugging Emco, Rohm and Bison as well!
              #380946
              ega
                @ega
                Joseph Noci:
                Many thanks. I note in the second photo that you have rotated the turret body away from the operator. I am always looking for ways to reduce tool projection on my own device, hence my interest.
                #396010
                IRT
                  @irt
                  Finally got around to having a look at an SC4 today.
                  Could not really find fault in it, but it was not the step up in size that I was expecting from the SC3. Not as much metal on the compound slide as I had hoped for.
                  I think I need something a little bigger so back to looking at Warco, and the Warco 250V.
                  Unfortunately it is a 176 mile journey to Warco to see one.
                  Is there anyone in Staffordshire/Shropshire area using one, willing to would let me have a look at it, and share their views and experiences?
                  The contingency play is to search out decent metric AUD/BUD but that is proving harder than I had expected.
                  #396016
                  Vic
                    @vic
                    Another one to look out for may be the Viceroy.
                    A mate who works in a school says they got rid of two of them some years back and they showed little sign of any hard use.
                    #396020
                    IRT
                      @irt
                      The Viceroy is 54" long. I don't think I could fit one in. I am very restricted in my choice by the space I have available.
                      #396031
                      Hopper
                        @hopper
                        Posted by Ian Thomson 2 on 12/02/2019 20:22:50:
                        Perhaps revisit your original idea in your first post and think about a Boxford? A low mileage example would be a good machine. Perhaps get some help via the forum with finding or inspecting a good example? Or one from a dealer with some kind of guarantee or warranty?
                        I know the Australian equivalent South Bend clone, the Hercus, is a very good machine, having used them over the years at various jobs and tech college etc. They are good and solid. Sort of the next size up from a Myford.
                        Also a good used Raglan would be worth looking into as well.
                        #396035
                        IRT
                          @irt
                          The Raglan is one on my shortlist. What appeared to be a good example came up on ebay a few weeks ago and not too far from me. Unfortunately the seller would not let me go and look at it before the bidding ended. It may have been a good lathe, but I wasn't going to risk it.
                          #396036
                          Hopper
                            @hopper
                            Posted by Ian Thomson 2 on 13/02/2019 06:21:40:
                            Wise move. I would not buy sight-unseen unless the price was rockbottom giveaway low.
                            The thing with buying used is you have to be prepared to put the time in to wait for good machine to come up at a good price. New is certainly the convenient option.
                            #396044
                              The compound on the SC4 seems to be fine in practice.
                              Have you had a look at an AUD/BUD yet? Although the centre height is 1/2" higher than the SC4 and an inch more than a mini lathe/S7, and the between centres distance is only an inch more than the SC4 500.
                              If you want a significantly greater capacity you may need to look for something a tad bigger again like a Colchester Student.
                                There are several other sellers of "250" or "280" size lathes around the country that you could go and look at even if you eventually decide to buy the Warco one, they all have the same basic construction which will give you a good idea of size and mass, fine detail may vary but not size..
                                Chesters would be the closest
                                Edited By JasonB on 13/02/2019 08:55:50
                                #396078
                                IRT
                                  @irt
                                  I have considered the Colchester offerings too, I can't even squeeze the bantam in to the space available .
                                  I will have a driver over to the Chester showroom next time I get a day off.
                                  #396099
                                  not done it yet
                                    @notdoneityet
                                    I generally keep an eye on Raglans as they arise on epay etc. There was one 5”, recently on epay, that had no changewheels or gear train and an almost empty apron. It was a BIN reduced, steadily, from £650 down to £300. Glad you didn’t get that one! Seller was a right bent epayer as he knew it was very incomplete!
                                    Apparently a good looking 5“ was sold recently as a Colchester, or similar. Buyer either got a good bargain (at £300 including an original taper turning accessory, amongst other tooling), or would have been mightily surprised!
                                    I would recommend the 5” with QCGB over a Little John any day. The LJ (with QCGB) was a good lathe but the 5” is far superior in several ways.
                                    My QCGB 5” came with two fair quality chucks (TOSS), both steadies and faceplate (along with sundry other tooling) – and was already fitted with a 230V three phase motor and VFD.
