SmallRig Cheese Plate
Home › Forums › Workshop Tools and Tooling › SmallRig Cheese Plate
  • #855781
      I bought a couple of these little ‘1598’ plates to mount things on the optical bench.
      … I had heard that SmallRig quality was good, but never previously purchased anything from them.
      Frankly … the quality of this product, and the packaging, are exceptional
      and buying from the ebay store avoids the risk of import charges etc.
      https://www.smallrig.com/uk/search?wd=cheese%20plate&type=input&t=1783570880265
      #855787
      John Haine
        @johnhaine32865
        Not so good for gooey brie though? 😀
        #855794
          Certainly not in this weather, John
            Forgot to mention …
            In case anyone is wondering about that 9mm pitch for the grid:
            It’s to provide compatibility with the Arri pin-lock arrangement, and thereby opens-up the world of NATO -Rail accessories
            Ref: https://www.arri.com/resource/blob/320202/04f5271d1d21f8c7db4a460d2e871b44/pin-lock-standard-download-data.pdf
            Ref. https://en.wikipedia.org/wiki/NATO_Accessory_Rail
            #855882
              Observant readers [if they are interested] will have noticed that Arri’s drawings show a pitch radius of 10.4mm … which is not simply related to 9mm
              I have been discussing this anomaly with ChatGPT … and its closing remark was
              I would actually enjoy reverse-engineering this standard from first principles. If we treat the ARRI drawing as the final answer, we can work backwards and derive the likely design constraints that force the radius to land very close to 10.4 mm. I suspect we can reconstruct the optimisation to within a few tenths of a millimetre, and it would make a nice mechanical design exercise rather than just a geometry problem.
              Can anyone beat that ?
              Nigel Graham 2
                @nigelgraham2
                That reads like a lot of rather patronising waffle to say “We can put the holes anywhere”!
                #855892
                  That’s a typically derisory response, Nigel
                  I would be interested to see what you think of Arri’s own launch-statement and the discussion thereof:
                  https://www.facebook.com/ARRIPCA/posts/arri-in-consultation-with-other-accessory-manufacturers-has-introduced-a-new-sta/645334880956570/
                    [ Enlightenment at last ]
                    The little 1598 plates are ideal for my optical bench … BUT
                    IMG_1823
                    Nealeb
                      @nealeb
                      Michael’s quote from ChatGPT was interesting as it could almost be confused with a human response. However, never having heard of a cheese plate I asked ChatGPT what one was. It told me it was a plate on which to serve cheese…
                      #855908
