Tap and Die sets
Tap and Die sets
Home › Forums › Workshop Tools and Tooling › Tap and Die sets
  • #186964
    andrew winks
      @andrewwinks64215
      Hi all, my limited knowledge of metallurgy of taps and dies is being tested, I know that there is HSS and Carbon Steel, in order of quality and durability but what is Alloy Steel with HRC 58-62 ?
      I'm in the market for a new metric set, fine and coarse thread, and the above grade steel is mentioned for a kit from Korea. I doubt most general public buyers including myself would understand what this means in terms of quality and longevity and best metals to use with. I want a general use kit that will cut mild steel and the non ferrous with the occasional stainless thread. Comments greatly appreciated. Cheers, Andrew
      #17680
      andrew winks
        @andrewwinks64215
        #186973
        Capstan Speaking
          @capstanspeaking95294
          It sounds like Hardness, Rockwell scale C. 58 to 62 is the top end of what you can get from carbon steel.
          Steel is an alloy anyway so the title "Alloy" is meaningless.
          For light occasional use in soft, low abrasion materials, carbon steel will do fine.
          Edited By Capstan Speaking on 19/04/2015 15:09:30
          #186974
          paul 1950
            @paul1950
            buy a cheap set and replace the ones you are going to use a lot with Dormer, they are often cheaper on eBay they have a habit of ending up there.
