Softening a hardened tool holder
Home › Forums › General Questions › Softening a hardened tool holder
  • #141257
    Bill Robley
      @billrobley
      So, I bought a lathe tool holder from the Ally Pally show on Saturday with a view to modifying it at a later stage to fit my CL300.
      Life being what it is, when I got it to my shed and tried a file on it, it's harder than a very hard thing, the file skidded off without leaving a mark (Sigh)
      Now, I have no idea what steel this is made from but can I assume that if I heat it to cherry red and let it air cool it will become workable or is it going to be more elaborate than that?
      Fortunately I only have a few Queen's heads invested in this so it's not the end of the world if I can't do anything with it, though it would be nice if I could make it usable.
      Heading SHOULD have read annealing, Sorry, fingers outrunning brain (As usual )  )
      Edited By Bill Robley on 21/01/2014 09:10:04
      #23089
      Bill Robley
        @billrobley
        #141259
        Involute Curve
          @involutecurve
          You will need to hold the red heat for a while depending on its cross section it will also need to cool slowley, if I need to do this sort of thing, I used to throw it in the fire and leave it over night to cool, I now have a heat treatment oven so use this instead ……….
          having said that if you hold it at red heat for five mins then cool it slow you might get away with it…….
          Shaun
          #141264
          Speedy Builder5
            @speedybuilder5
            If you have a log stove, put it inside a tin packed tight with ashes and leave it in the middle of the fire for a few hours when its going well then let it cool down as the fire goes out overnight.
            You could take it to a small m/c shop and ask them to surface grind it down for you. (Would save the bother of annealing it).
            Do you need to harden it once it has been modified ?
            #141278
            Tony Pratt 1
              @tonypratt1
              Heat to red heat for 1/2 hour and cool as slowly as you can. Wrap in some thin sheet metal to avoid scaling.
              Tony
              #141282
              Sub Mandrel
                @submandrel
                What modification do you nee to make? is it to reduce height or bore out the fixing hole?
                Howard Lewis
                  @howardlewis46836
                  If it is to reduce the height, you could rough it out with an angle grinder, and then get the local machine shop to finish to size on a surface grinder.
                  #141319
                  jason udall
                    @jasonudall57142
                    Angle grinder. .then carbide mill?
                    #141337
                    Ian S C
                      @iansc
                      Here is a tool made from a HSS flat bit, the original drill bit is in my album. Hardend all over, most ly cut with the angle grinder, the bottom ground flat with a cup stone in the vertical mill(well covered). I,v made 2 of them, and have another one that can be done at a later date. Ian S C023 (640x480).jpg
                      #141338
                      Bill Robley
                        @billrobley
                        The tool in question is a small (ish) tangential tool holder that I thought I might like to try on my lathe, however, the main body of the tool holder protrudes too far out of the front of the tool holder, pushing it beyond the centre point on my lathe (Clarke CL300) so I think, with the lack of treating oven, it might come down to careful use of an angle grinder and bench grinder to finish off.
                        Thank you very much to all who replied, I appreciate your comments and ideas.smiley
