Small parallels
Small parallels
  • #817484
    old mart
      @oldmart
      Is there a source of small parallels suitable for use in vises of 3″ and smaller? Or at least some ground square stock that could do.
      #817487
      Howard Lewis
        @howardlewis46836
        Toolbits should suffice, sizes from 1/8″ up to 1/2″ square.
        #817491
        Andrew Tinsley
          @andrewtinsley63637
          They certainly exist and I purchased a set from ARC a month or so ago. But probably no longer available from ARC.
          Andrew.
          #817497
          old mart
            @oldmart
            Thanks for pointing me in the right direction, I have just ordered 2×2, 3×3 and 4x4mm HSS in 200mm lengths which can be easily cut into useful lengths
            #817501
            Nicholas Farr
              @nicholasfarr14254
              Hi, yes Arc did have those that Andrew mentioned, and no, they don’t have any at all now. RDG have some 80mm long ones, but they may be more than you what to pay for them.
              80mm Parallel set
              Regards Nick.
              #817502
              old mart
                @oldmart
                I bought a set of those parallels years ago when they were about £40, very useful, but too big, except at the small end for what is needed at the moment. Now that I have a second look, the set I bought has more and they vary in thickness from 6mm to 3mm.
                I have just ordered a box of parallels, ten pairs of 1/8″ thick from 1/2″ to 1 5/8″ by 6″ long on ebay which I couldn’t resist for under £25 to use on the mills in addition to the set of 1/32″ thick ones plus loads of bigger ones that have been donated over the years, we do have loads of tooling here.
                #817505
                Andrew Crow
                  @andrewcrow91475
                  I have used small HSS tool bits as parallels for many years, however just a word of warning, they are not always absolutely equal size on each side. There is often a bit of variation in size so if you want exact squareness and parallelism just check before use.
                  Andy.
                  #817510
                  old mart
                    @oldmart
                    #817520
                    cogdobbler
                      @cogdobbler
                      I use key steel cut into suitable lengths.
                      #817579
                      Vic
                        @vic
                        Most of mine are bits of Ground Flat Stock left over from other jobs. Old Bearing Races, particularly the inner, come in handy for some jobs.
                        Blast, that’s another job. I’ve just realised I’ve got some old races from which to harvest the inners …
                        #817740
                        old mart
                          @oldmart
                          The box of ten pairs of larger 6″  parallels from ebay arrived yesterday all 1/8″ thick and from 1/2″ up to 1 5/8″ wide and for £25 the set is a bargain for normal size mills.
                          #817784
                          Huub
                            @huub
                            I mill my parallels out of mild steel. I chamfer the right corner so I can reposition them the same way they where milled. Any vertical misalignment of my mill or vice is reduced to zero. If I accidentally drill a hole in the parallel, the drill is not damaged.
                            #817787
                            John Haine
                              @johnhaine32865
                              If using old races, check for any slight burrs on the edges.  First time I used one on my brand new mill table it embossed a narrow circle into the pristine surface. Easy to stone off the burr.
                              #817795
                              Vic
                                @vic
                                Good tip John.
                                #817861
                                  As the usual holes in parallels don’t seem to get used it would be an option to buy a 6″ set and just cut them all in half. You could still hang them on a nail in the workshop wall if you wanted as that only needs 1 hole in each.
                                  #817867
                                  Andy Stopford
                                    @andystopford50521
                                    Also, if using old ball races, check the thicknesses if using more than one, even if they’ve come from the same application, e.g a pair of car hub bearings.
                                    I once used some Land Rover hub bearing outer races as parallels to mount a large scrapyard-find faceplate on the standard Harrison faceplate to bore and thread a new mounting.
                                    When I screwed it onto the spindle I found I’d basically made a swash plate – one of the bearing races was a few thou narrower than the other two; not noticeable when concentrating on getting the mounting register, etc. right, but when magnified at the edge of a 15 or 16″ faceplate – unfortunate. It was quite a bit thinner by the time I’d skimmed it true.
