Small Injectors
Small Injectors
Home › Forums › General Questions › Small Injectors
  • #104458
    Tom Dixon 1
      @tomdixon1
      I am currently building a 5 inch gauge Bagnall 'Brick' in 1/5th scale.
      It is calculated to require 2.6oz of water per minute to be running at a sedate 5 mph which is our club's normal passenger running speed.
      Are there any live steam injectors available that has a small feed volume? So that it could be left on continuously to keep the boiler water level constant with another injector to top it up.
      #22340
      Tom Dixon 1
        @tomdixon1
        For a 5 inch gauge locomotive
        #104476
        julian atkins
          @julianatkins58923
          there is no requirement in miniature to have such a small injector so it can be left on. whilst 4 oz pm and 8 oz pm injector designs are available and have been made, the smallest practicable size is really 12 oz pm for most locos. try polly engineering and see if you can get a chiverton injector of this size as they are the best commercially available IMHO (usual disclaimer). i make my own so dont have to worry!
          cheers,
          julian
          #104482
          Grizzly bear
            @grizzlybear
            Hi Tom. I haven't mastered 'Links' yet. **LINK**
            This link is just for info.
            Regards Bear..
            #104483
            Grizzly bear
              @grizzlybear
              My Link works!
              Bear..
              #104556
              Tom Dixon 1
                @tomdixon1
                Julian Atkins: Thank you very much for the reply I shall look into the Chiverton Injectors as so far several people have informed me about their reliability.
                Grizzly Bear: Thanks also for that web link because that throws more light onto the unusual engine, so far I have drawn her up by scaling up an 16mm Archangel Model and then corrected the gauge for a scale 1ft 8 inch.
                Tom
