Silver soldering problem
Home › Forums › Help and Assistance! (Offered or Wanted) › Silver soldering problem
  • #360361
    BOB BLACKSHAW 1
      @bobblackshaw1
      I made a mistake on a brass part that can be repaired with a fill in of silver solder using Easy- Flow flux, all went well on this yesterday.
      Today making another using the same brass I again made the same mistake, but this time the solder would not take it just run off in ball. I cleaned the brass using a wire brush and diamond needle file as yesterday, tried several times but would not take.
      I've muck it up now by using a brazing rod which did take but melted the edge of the job.
      Any idea why the silver solder worked a treat on one but not the other, as they came off the same 44mm round brass.
      Thanks Bob.
      #33229
      BOB BLACKSHAW 1
        @bobblackshaw1
        #360367
        Mick B1
          @mickb1
          Did you use enough flux? In my own tentative forays into silver soldering I've found I had to paint on quite a coating.
          Still scares me, and I'll bolt the joint instead if I can…
          #360368
          Brian Sweeting 2
            @briansweeting2
            You say that you melted the end of the job.
            If you overheat the base then the filler will simply run off, the flux has already benn burnt away.
            #360372
            BOB BLACKSHAW 1
              @bobblackshaw1
              I melted the edge of the job when using a brazing rod, but that did take, not the silver solder.
              #360386
              Keith Hale
                @keithhale68713
                Hi Bob.
                Email details to me with the grade of silver solder you are using.
                If the solder melts but don’t wet the brass you have a flux problem. The flux is not compatible with the solder/heating technique/parent materials.
                Keith
                #360403
                Bob Stevenson
                  @bobstevenson13909
                  Either contamination or a flux failure…..
