hi Brian,
you are about to embark on quite a costly part of the build, and i would encourage anyone to have a go at their own boiler to a published design, so good luck.
however it is easy to make a real hash of things if done in the wrong order, wrong fits, wrong methods, wrong set ups and heat etc. add to this list use of correct grade of silver solder and flux for boiler making.
i would strongly endorse Nigel Bennett's excellent advice. J-M Easyflow flux is ok for small non ferrous components ideally with the old cadmium bearing easyflo and easyflo2 silver solders. for J-M silverflo55 silver solder you are really pushing the flux. it is totally unsuitable as a flux for long heat ups required for boiler work.
Nigel has suggested J-M Tenacity 5 which is designed for stainless but quite ok. i use Tenacity 4A or its equivalent Thessco F flux for boiler work. Alec Farmer recommended i use Thessco F 30 years ago for my first boiler, as this is what Alec used himself.
any flux deposits with these are removed by a soak in a hot solution of sodium hydroxide, as recommended by J-M themselves.
if you use easyflo flux for making your boiler that will be your first mistake!
second mistake is not joining a local ME club. you will also need to get all stages of the boiler construction checked by the club boiler inspector as you go along, and he may also require departures/updating of the original design to comply with the current boiler regs.
cheers,
julian
Edited By julian atkins on 11/11/2015 16:44:21
