Sherline motor died
Sherline motor died
Home Forums General Questions Sherline motor died
Viewing 15 posts - 1 through 15 (of 15 total)
  • #27882
    Steve Crow
      @stevecrow46066
      #518921
      Steve Crow
        @stevecrow46066
        Today, halfway through a camshaft, my lathe motor stopped working.
        No noise, no smell, no smoke, no drama. I stopped to take a measurement and it wouldn't restart.
        At first I though it might be the thermal protection kicking in but it's the same now it's cool. I've checked the fuse on the plug.
        I have very little knowledge of all things electrical.
        Before I attempt to dismantle things and look for something wrong, has anyone any experience of these things or advice they could share?
        Many thanks
        Steve
        #518945
          This might be relevant, Steve: **LINK**
          DC Motor Internal Brush – 2020 Upgrade Notice
          And, assuming you have the older motor, this:
          https://www.sherline.com/wp-content/uploads/2016/01/dc_ext_brush.pdf
          Edited By Michael Gilligan on 10/01/2021 18:32:46
          #518952
          Ady1
            @ady1
            If its the brushes you can shake it about and get a bit of life from the motor before it goes completely dead
            Check your plug wiring is live, a sudden death with no fuss like arcing buzzing hesitant spindle movement or smoke is quite weird
            You can also sometimes kick start a motor, spin it by hand, then once your fingers are safely clear switch it on
            Edited By Ady1 on 10/01/2021 18:57:57
            #518972
            Emgee
              @emgee
              Following the link above to see the explanation for the move to internal brushes that have to be replaced at the factory, could someone please explain how more torque is obtained with internal brushes fitted in the same orientation as external brush holders.
              I can see the motor costing less to manufacture with fixed internal brushes but it doesn't help the European user when it comes to checking or replacing brushes.
              Seems to me Sherline are making the motor a throw away item with the carriage costs involved.
              Emgee
              #519043
                Emgee
                I’m not sure what they are comparing with what, in that claim
                … but this is an interesting read:**LINK**
                DC Motor and Speed Control Unit
                Edit: __ it may be worth browsing around here for enlightenment:
                https://www.hillhouseproducts.com/new-page
                Edited By Michael Gilligan on 11/01/2021 09:56:32
                #519054
                larry phelan 1
                  @larryphelan1
                  Seems a lot-of-lolly to pay for a throw-away-motor ??frown
                  #519057
                  Emgee
                    @emgee
                    Posted by larry phelan 1 on 11/01/2021 10:39:38:
                    Agreed especially if you add £30-£50 carriage cost to Europe, and it is only 60W output working at maximum 5mins on 15mins off. There must be a better alternative available if you look hard enough.
                    Emgee
                    #519058
                    Emgee
                      @emgee
                      Michael
                      Those links didn't answer my question about getting more power with motor enclosed brushes !!!!
                      Emgee
                      Edited By Emgee on 11/01/2021 10:55:50
                      #519059
                      Danny M2Z
                        @dannym2z
                        My original (Australian) Sherline lathe ((brass bed) wvas powered with a sewing machine motor with a lamp dimmer as the speed control and a rubber 'O' ring belt drive. A bit scary at high rpm when the drive belt went a bi oval but a great lathe for making modekl engine parrts such as spraybars and needlle valves
                        #519067
                          Posted by Emgee on 11/01/2021 10:55:08:
                          Michael
                          Emgee
                          No they didn’t … I was leaving it to you to deduce that the statement* is badly [or perhaps cleverly] written, and that we are actually looking at coincidental events that are not ‘cause and effect’.
                          * May I repeat …. I’m not sure what they are comparing with what, in that claim
                          Edited By Michael Gilligan on 11/01/2021 11:48:50
                          #519069
                          Emgee
                            @emgee
                            Posted by Michael Gilligan on 11/01/2021 11:46:22:
                            Michael
                            Emgee
                            Seems to me they are comparing the old motor with external brush holders to the new motor with enclosed brush holders.
                            I have searched without success for evidence to support the claim of more power so the word I find for the description may not be within the site rules.
                            Emgee
                            #519075
                              Posted by Emgee on 11/01/2021 11:55:59:
                              But is the use of external or internal brushes the only difference between the two motors that are being compared ?
                              … or is it just a convenient point of reference [an aide mémoire] ?
                              Sorry, I don’t know the answer, and I’m not sufficiently interested to pursue it further.
                              Edited By Michael Gilligan on 11/01/2021 12:25:00
                              #519077
                              Steve Crow
                                @stevecrow46066
                                I plugged the motor in this morning and it worked fine!
                                It must have been the thermal protection though it was still dead 4 hours after it cut out.
                                Thanks for all your advice and sorry if I have wasted your time.
                                Steve
                                #519082
                                Howard Lewis
                                  @howardlewis46836
                                  A friend, (like me, careful ) replaced the brushes in his Flymo (Seemingly not intended to be replaced ) by carefully bending up the end of the brass brush box. Having found and fitted suitable replacement brushes he then bent the bras back down, and resumed mowing the grass.
                                  Possibly the Sherline motor could be restored to life in a similar way, if necessary?
