Trying to remove wood screws from a panel door, I have sheared two of them flush with the surface behind the door handle.
They are of the hardened type, 3.2mm diameter and there is 20mm stuck in the wood. Any suggestions on how to remove the screws please?
My thought at the moment is to make a core drill that will just pass over the screw and OD about 4.5 – 5.0mm. When deep enough, i will try and get long nose pliers on the end and try and break off the peg. Afterwards I will fill the hole with a dowel.
The Emerald Isle
