I have a 47 year old Seiko watch. Unfortunately the manufacturers in their wisdom at the time chose to incorporate a couple of plastic components. These have now succumbed from the from aging and embrittlement. Fortunately one of these plastics, a little gear, is now available in steel, for repairs.
The other part is a slightly complex moulded ring, roughly around 29mm diameter 2x2mm in section. This holds the face in place when the back is tightened. Over the years, at cleaning time, this ring has been found cracked and has been repaired by epoxy. However, the ring now appears to be crumbling at contact points and releasing particles in the movement.
I have toyed with the idea of making a new one from something like delrin of ptfe but this wont be an easy task because of the various cut-outs and other features.
In the meantime I have managed to find “new” ring, well, “unused” one (they are rare) and Im wondering about using it in the watch to save me some hard work. However I suspect this ‘new’ part was probably manufactured around the time of the original. It may therefore already be embrittled to a greater or lesser extent, depending on storage temperature.
A few times the subject of ‘plasticiser migration/out-gassing’ has been described on this forum. What I’m wondering is whether there is anyway to re-infuse plasticiser into this material and hopefully give the part a longer lease of life? … I’m thinking of some kind of vacuum process, such as used to infuse preservative into wooden fence posts. Anyone have any knowledge of this?
Gerry
