Not long ago, I need to tap some 5 x 0.5 mm holes, only 3.5 mm deep, so the tap was ground to a flat end. Fortunately, it worked O K despite having no lead in chamfer.
Depending on size of tap either a centre hole or a point is left by the manufacturer. They are there so that the tap can be accurately aligned on a tool and cutter grinder for resharpening.
