Piston ring
Piston ring
Home Forums General Questions Piston ring
  • #524084
    BOB BLACKSHAW 1
      @bobblackshaw1
      Hello all,
      I usually make my cylinders out of brass or aluminium as the cylinders are no more than 1/2 inch bore. The cylinder I am making is the full size Stuart with the 3/4 inch bore made out of cast iron. I use viton rings on brass and aluminium will a viton ring be okay to use on cast iron, or what is the best material to use on cast for rings.
      Thanks Bob
      #27933
      BOB BLACKSHAW 1
        @bobblackshaw1
        #524146
        Lee Rogers
          @leerogers95060
          You could do worse than look at the latest youtube by Mr Crispin. Not your average tuber , RR trained toolmaker and highly reccommended.
          #524147
            I've used Viton in a number of CI cylinders with no problem, just give the cylinder a Home with a cheap brake cylinder hone to remove any turning ridges.
            Don't use the makers figures for ring compression as they will create too much friction.
            If it is just a 10V or 10H then you don't really need rings, just add the oil grooves as shown on the drawings, 1000s have been built that way.
            Edited By JasonB on 01/02/2021 16:21:08
            #524150
            duncan webster 1
              @duncanwebster1
              Proper cast iron made to the words of Tubal Cain (TDWalshaw). It can't be that difficult as I achieved it, but you might need a a split piston with such a small bore. I made mine 0.45" sq. If you only want it to work on low pressure for display then just make the piston a good fit and turn some oil retention grooves in it
