Pansy – where does the lubricator go??
Home Forums Beginners questions Pansy – where does the lubricator go??
Viewing 15 posts - 1 through 15 (of 15 total)
  • #185520
    Phil Catchesides
      @philcatchesides15448
      Got a lubricator, got a chassis – no room ! There is a foul between draw hook shaft, angles for fixing buffer beam and cylinder block. Drawing shows it directly behind hook which is clearly wrong. Where does it go??
      Thanks, Phil
      #7553
      Phil Catchesides
        #185527
        wendy jackson
          @wendyjackson
          hi, the lubricator does seat behind the front buffer. You can see the position on the Pansy I am working on. if you would like me to take some further pictures please ask. michael
          #185528
          wendy jackson
            @wendyjackson
            <a href="**LINK**" target="_blank"><img src="**LINK**" border="0" alt="pansy photo pansy pic.jpg"/></a>
            #185544
              HOW TO POST IMAGES HOSTED ON PHOTOBUCKET
              It's top of the list of FAQs
              Edited By Neil Wyatt on 04/04/2015 19:15:15
              #185546
              Phil Catchesides
                Thanks Terry, is your front hook sprung? My hook-stem with spring, nut and washer extends behind the bumper by about 1" and is about 1/4" diameter so lub. has to miss that. I will try and take a picture tomorrow if I haven't solved it. I know it is a big ask but any chance of a pic. from underneath?
                Phil
                #185575
                wendy jackson
                  @wendyjackson
                  Hi phil, will take pics tomorrow showing all angles.michael
                  #185592
                  Anthony Kendall
                    @anthonykendall53479
                    You seem to have decided on a mechanical lubricator. There is another alternative – a displacement lubricator. The picture shows one fitted to a Pansy cab – the output remains to be connected at the top and down through the hole next to the boiler. The expansion tank fits neatly under the floor between the back axle and the brake operating shaft.
                    Although this offering does not look prototypical, this type of lubricator is prototypical to the 57XX.
                    The cab of 5764 – the lubricator flow sight glasses are on the right (I think!)
                    All included in the best possible taste – it is probably not viable to change course now.
                    Hope it goes OK.
                    Edited By Anthony Kendall on 05/04/2015 09:48:21
                    Edited By Anthony Kendall on 05/04/2015 10:15:45
                    #185599
                    wendy jackson
                      @wendyjackson
                      pansy oil5.jpgpansy oil3.jpgpansy oil2.jpghi Phil, please find pics showing the position of my lubricator. the front hook is a solid fitment so know movement. michaelpansy oil1.jpg
                      #185603
                      Anthony Kendall
                        Apologies, I should have said hydrostatic, not displacement in the above (I think). Too late to edit.
                        Looks like Terry has the answer for you.
                        Edited By Anthony Kendall on 05/04/2015 10:27:21
                        Edited By Anthony Kendall on 05/04/2015 10:37:03
                        #185618
                        Phil Catchesides
                          Thanks all for help and pictures. Where I went wrong was building to drawing; the drawing has the drawhook going 1.25" back from front of buffer beam to accommodate a spring and this is impossible at the front with the lubricator. Another big error on the drawings and clearly LBSC never made the loco from his plans ! I will convert the hook to unsprung and then put the lubricator where it is shown on the plans
                          Thanks again, Phil
                          #185627
                          wendy jackson
                            @wendyjackson
                            Phil, if you would like the build notes please let me know your email address and I will send.michael
                            #185632
                            Phil Catchesides
                              Thanks Michael I have copies of the articles but they are full of 'I've described this many times before so I won't do it again' for critical operations and lots of text telling me the completely obvious. I had rather hoped that I could build the loco from the drawings but they are really only a reasonable indication of what is required (leaving aside those who think the valve set-up is all wrong). Another example that comes to mind – the motion plate. The cut out for the crosshead pump drive isn't on the frame drawing, it just 'appears' later when you have to strip the chassis down to remove the motion plate to put the cut-out in.
                              Anyway lubricator going in nicely now, the hook is solid to the buffer beam and I am doing the pipe, linkage and filler
                              Good job we didn't make Airbus' like this, Phil
                              #185645
                              KWIL
                                @kwil
                                Trouble with the "words and music" do not trust everything you read.crying
                                #185656
                                wendy jackson
                                  @wendyjackson
                                  Phil, How anyone can build anything from the plans beats me. I think back in the day these builds got done a lot of chaps worked it out together. these days I don't think that there is the level of building and so as a result the level of advice and no how is also dropping. My own Pansy dates to 1964 and Its nice to think that it is still giving joy after 51 years. michael
