New chainsaw
New chainsaw
Home › Forums › General Questions › New chainsaw
  • #102692
    John Stevenson 1
      @johnstevenson1
      Been to Comet today to see if I could get any bargains related to the workshop.
      Bought a chainsaw, got it home, unpacked it but having a few problems with it and wondered if the combined expertise of this forum could shed some light on how this works ?
      John S.
      #22303
      John Stevenson 1
        @johnstevenson1
        #102695
        Martin W
          @martinw
          I would have thought that the manual would have had a few useful 'links' showing how to use it cheeky! You could write to the manufacturer for advice but they are likely to reply by chain mail.
          Hope you sort it out.
          Cheers
          Martin
          ps You have far too much time on your hands wink 2.
          #102697
          Trevor Drabble 1
            @trevordrabble1
            John,
            Can spot 3 problems straight away ! One is that the wing nut is at the back rather than the front where it should be , and also, assuming one is right handed, starting will be almost impossible , because the pull cord is on the wrong side of the handle ! And finally, the pitch of the teeth is far too coarse for normal use, which may explain why it was bargain. Assume they had run out of finer pitch versions ?
            Trevor.
            #102701
            NJH
              @njh
              Hi John
              I think you were sold a pup there but – fear not – I've managed to fix it for you.
              I know it's a bit rough but I hope you don't feel too "sore" about it!
              I know you favour the bigger jobs so maybe it will come in useful.
              Cheers
              Norman
              Edited By NJH on 04/11/2012 00:57:59
              #102715
              Les Jones 1
                @lesjones1
                Hi John,
                I think it's a design to meet health and safety standards so you can't cut yourself with it.
                Les.
                #102720
                Gordon W
                  @gordonw
                  It will cut perfectly well, just needs the speed increased.
                  #102722
                  FMES
                    @fmes
                    They didn't have any left handed versions left, did they?
                    #102723
                    Ian S C
                      @iansc
                      You sure its not an electric saw, either the battery is flat, or its a mains one, and they forgot to give you the plug, There's a bloke it Christchurch NZ who has had one for many years, his has a three pin plug (female), on a short flex. Ian S C
                      #102736
                      Bazyle
                        @bazyle
                        I prefer a brass band saw but as the tuba player is at Sandown today I'm using my small bandsaw.
                        #102738
                        Martin W
                          @martinw
                          Bazyle
                          Had thought about buying one of those but it was stretching my budget too far and besides the company couldn't or wouldn't supply the figures for the elastic limit of the blade crook.
                          Cheers
                          ps Rymans do a good selection of blades at reasonable prices and they are colour coded as well.
                          #102740
                          Stovepipe
                            @stovepipe
                            …and ArcEuro part number is ???????
                            Dennis
                            #102743
                            NJH
                              @njh
                              No Dennis
                              I think the ArcEuro part No. is more likely to be *******!!!
                              No doubt John will enlighten us when he finally gets up!
                              N
                              #102744
                              harold
                                @harold
                                I think you may have misinterpreted the instructions. The saw will obviously fail to work in its current orientation. Turn it around so that the handle is on the right and all will be well.
                                HTH.
                                #102750
                                Sub Mandrel
                                  @submandrel
                                  You're all missing the point – it's an electric chainsaw, probably three phase, it just needs to be plugged in.
                                  The only chainsore I've got is from this one around my ankle…
                                  speelwerk
                                    @speelwerk
                                    Its a most rare model for a prison chain gang.
                                    Niko.
                                    #102756
                                    Bazyle
                                      @bazyle
                                      thanks for the tip Martin, I got the red one mail order – well the postman brought it anyway.
                                      By the way mine is not electric, it is powered by Custard Creames.
                                      #103107
                                      Cyril Bonnett
                                        @cyrilbonnett24790
                                        Did you remove the chain guard on your chain saw as sawing chains without it you'll have links flying every where, then you spend ages hunting for the missing links. My advice wood be to take it back to the chain store, get your money back head for the pubsmile p
                                        #103156
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi John, was it advertised as an engineers chainsaw? Because I reckon it's a fake if it was. It must be about 99 feet to short, and that might be why it's not working properly.
                                          If it is a surveyors one, then it's still about 65 feet to short.
                                          Regards Nick.
