So, the 7×12 mini lathe has a gear (A) driven 1:1 by the spindle via a tumble reverse, and one that drives that leadscrew 1:1 (D) . It then has a single moveable layshaft on which a pair of gears (B, C) can be fitted to obtain a different ratio, B meshes with A, and C meshes with D.
Or a single gear can fit where B&C go, to drive directly from (A) the spindle to the (D) leadscrew in which case, any gear will do as its just "passing it on" so whatever fits comfortably (use a larger one, the small gears will wear out quicker and the 20T's are weak due to the keyway)
So, I believe the standard gears are as follow
2x 20T
2x 80T
and you get the follow as an extra for screw cutting (some/most? vendors include them now and I can't seem to find anyone selling them – so I'm 3D printing them which is much more fun)
1x 25T
1x 30T
2x 40T
1x 45T
1x 50T
1x 55T
1x 57T
1x 60T
So, here are the combinations that achieve more accurate metric threads, I've not tested these actually fit since some gears will just be too large (the centre to centre of C & D + the radius of the leadscrew must always exceed the radius of B, and if C is much larger than B, it will hit the washer that holds A, but it doesnt look too close to me. I have stared at it, and the possible combinations so hopefully, these are compatible. Some combinations might simply call for too many large gears, and there wont be room – we'll see I guess.
| Desired Pitch (mm) |
A |
B |
C |
D |
Actual |
Error |
| 0.400 |
20 |
1 |
1 |
80 |
0.396875 |
0.781 |
| 0.450 |
20 |
65 |
55 |
60 |
0.447756 |
0.499 |
| 0.500 |
20 |
57 |
45 |
50 |
0.501316 |
-0.263 |
| 0.700 |
45 |
55 |
35 |
65 |
0.699388 |
0.087 |
| 0.800 |
45 |
55 |
40 |
65 |
0.799301 |
0.087 |
| 1.000 |
45 |
55 |
50 |
65 |
0.999126 |
0.087 |
| 1.250 |
35 |
40 |
45 |
50 |
1.250156 |
-0.013 |
| 1.500 |
65 |
55 |
40 |
50 |
1.500909 |
-0.061 |
| 1.750 |
40 |
57 |
55 |
35 |
1.750627 |
-0.036 |
| 2.000 |
40 |
50 |
55 |
35 |
1.995714 |
0.214 |
| 2.500 |
65 |
55 |
60 |
45 |
2.501515 |
-0.061 |
