mystery tool
mystery tool
Home › Forums › The Tea Room › mystery tool
  • #428608
    mal webber
      @malwebber91786
      Hi can anyone enlighten what these are for ,the only thing I good come up with are some sort of injector seat cleaning or something to that effect.
      Thanks Mal.
      img_20190908_105600.jpgimg_20190908_105553.jpgimg_20190908_105545.jpgimg_20190908_105537.jpg
      #35611
      mal webber
        @malwebber91786
        mystery tool
        #428609
        charadam
          @charadam
          Domestic (or other) water tap seat recutting tools.
          Edited By charadam on 11/09/2019 23:52:20
          #428610
          Bill Phinn
            @billphinn90025
            They look like tap reseating tools to me, Mal.
            eta: beaten to it.
            Edited By Bill Phinn on 11/09/2019 23:51:49
            #428611
            Swarf Maker
              @swarfmaker85383
              It's a re-seating tool for water taps. The brass bodied kind of tap with a rubber washer.
              #428612
              Swarf Maker
                @swarfmaker85383
                All together now chaps!
                #428613
                Dennis R
                  @dennisr
                  They are valve seat cutters, the tapered threaded part screws into different size valve holes inorder to make it more adaptable.
                  Dennis
                  Beaten to it!
                  Edited By Dennis R on 11/09/2019 23:54:02
                  #428614
                  mal webber
                    @malwebber91786
                    Thanks every one now I know what there for now 'had these for years but had no idea what they were yes
                    Mal.
                    Edited By mal webber on 12/09/2019 00:00:31
                    #428615
                    Jeff Dayman
                      @jeffdayman43397
                      I'm pretty sure it is for doing dental work on elephants.
                      (could be wrong, the plumbers above could be right) laugh
                      #428623
                      I.M. OUTAHERE
                        @i-m-outahere
                        Sphincter surfacing tool 😀
                        I once machined down the diameter of the cutter to use as a spot face cutter for spot facing the opposite side of a base mounting hole on one of my model engines , a bit fiddly but it worked !
                        #428627
                        Speedy Builder5
                          @speedybuilder5
                          Similar ones used for removing piles ?
                          #428628
                          not done it yet
                            @notdoneityet
                            Last two posts are a load of ‘excrement’!
                            Any more anal ideas?smiley
                            #429819
                            Nigel Graham 2
                              @nigelgraham2
                              I have a random bound volume of about WW1 vintage, of Model Engineer. In it, one correspondent describes how he re-cut his kitchen tap seat.
                              Essentially he made something like a Keats Angle-plate from wood and bolts, to hold the lower half of the tap on his lathe face-plate.
                              Obviously he cannot have had a Mystery Tool, Taps, Domestic, for the Re-seating of.
                              The taps of his day were simple bib-cocks whose upper half could be unscrewed from only just above the seating. He probably had only one, cold, tap – and possibly in the whole house, not just on the scullery's porcelain sink – so not worth the cost of a Mystery Tool, ditto, when he already had a lathe.
