Mini mill riser block
Home › Forums › General Questions › Mini mill riser block
  • #449696
    Bob Perkins
      @bobperkins67044
      Hi all
      I would be interested to have some feedback on your thoughts, experience or comments on fitting a 50mm riser block at the base of the column of a mini mill to add a bit more distance between the spindle and table.
      thanks
      Bob
      #27114
      Bob Perkins
        @bobperkins67044
        #449699
        old mart
          @oldmart
          Good idea, you might even consider 75mm , but the existing height, quill movement and lowest clearance while milling very low work have to be taken into consideration.
          #449704
          Phil H1
            @philh196021
            Bob,
            I will keep an eye on this thread. I have a Chester 16V with quite a restriction on the spindle table distance – specially if I try to use a rotary table with 3 jaw chuck and drill chuck. I usually need to transfer over to my bench drill.
            The column is detachable – so it is possible (a spacer) but spacers would also be needed to raise the vice to ensure the milling cutter goes low enough – as old mart points out.
            Phil H
            #449705
            Dave Halford
              @davehalford22513
              Or to put it another way.
              You may need a raiser block for the milling vice as well for some small jobs smiley
              #449706
              Bob Perkins
                @bobperkins67044
                Hi Phil H
                I think there will be adequate travel on the spindle. I'm looking to overcome similar issues when I'm using a rotary table in the horizontal or vertical. I bought an 80mm swivel vice at the Ally Pally, and it's great, but has reduced the clearance I have a bit more than my old vice.
                #449709
                not done it yet
                  @notdoneityet
                  Posted by Dave Halford on 29/01/2020 20:48:33:
                  Or buy a vise with a rotating base – or rather one that is mounted on a base. Most discard the base for sundry reasons.🙂
                  #449713
                  old mart
                    @oldmart
                    You get the best of both worlds having a raiser block for the vise as well as the column. On a small mill, both blocks could be made from aluminium. A swivel base for a vise comes come in useful occasionally, and, as mentioned, adds height. Most vises with a base will fit on the table without the base.
                    Edited By old mart on 29/01/2020 21:13:00
