M.E. thread screws wanted
Home › Forums › General Questions › M.E. thread screws wanted
  • #140571
    ken king, King Design
      @kenkingkingdesign
      Does anyone know of a supplier of M.E. thread steel setscrews, specifically ⅛" x 40? I need a couple of different lengths in fairly small quantities. Any suggestions gratefully received.
      #23071
        @kenkingkingdesign
        Looking for a supplier of M.E. screws
        #140572
        John Baguley
          @johnbaguley78655
          I think 1/8" x 40 ME is the same as 1/8" BSW so try looking for those instead?
          Harry Wilkes
            @harrywilkes58467
            #140645
            HomeUse
              @homeuse
              I understand that ME threads are based on the BSW thread form so 1/8 x 40 and 5/32 x 32 are the same in both types (for the critical their could be a slight difference in the "Crest and Root&quot –
              #140658
              MICHAEL WILLIAMS
                @michaelwilliams41215
                Curious – Why do you need 1/8 – 40 ME screws ??
                Unless you are comitted to using existing tapped holes then use 5BA instead . Commonly available and nicer heads .
                The 26 32 40 and 60 tpi constant pitch series threads are all Whitworth standard form .
                They were ‘ proper ‘ engineering thread series but apart from 26 they were not much used except for Model Engineering work .
                Lovely boxed ME tap and die sets used to be available from several suppliers including Bond’s and Tyzack .
                In my early days buying catalogues was about the limit of my purchasing power and I used to look endlessly at the boxed sets and other wonderful things in the pictures .
                MikeW
                #140675
                roy entwistle
                  @royentwistle24699
                  Hi folks 26 tpi are used extensively on brass and also on cycles as I understand
                  Roy
                  #140684
                    @kenkingkingdesign
                    Reply to Michael, they are needed to fit existing tapped holes in cylinder head and crankcase of a model aero engine, and there's not enough meat to rethread with an alternative.
                    #140686
                      May just be easier to buy a bit of hex bar and a die and make your own, can't be that many in a small aero engine.
                      I wonder if you could get away with using 5-40 UNC which are 0.125" – 40tpi and at that size I doubt the 5 degree difference in thread angle will make a difference, even if it did you should be OK to tap with a UNC tap. Model fixings do 5-40 cap heads. If its an american engine than thats likely to be what was used anyway.
                      J
                      Edited By JasonB on 14/01/2014 19:18:49
