Good day, everyone, I wish to pick your brains ,since mine are not producing the answer I want.
My question is about setting up a steady on my lathe to support a piece of 50/60mm bar 600mm long.
I have read that the correct method is to set the work running true in the chuck [4 jaw ] and then set the steady close to the chuck, before moving it down the bed to the required position. OK so far, but how do I support the overhang while I am trying to get the chuck end to run true ? There is a fair weight in a piece of stock that length.
Some say to use a short piece of stock to adjust the chuck jaws and then replace with the job, but that assumes you have a spare piece to hand.
I ask this because I will need to do a job like this soon for a "friend" who thinks I know EVERYTHING, he is sadly mistaken, but I dont want to burst his bubble just yet.
All and any advice welcome.
