Help with lathe speed
Home › Forums › Manual machine tools › Help with lathe speed
  • #508861
    Neil Mccarthy 1
      @neilmccarthy1
      I am in the middle of restoring my Drummond b lathe and I was wondering if you can have a speed controller on a 240volt single phase ac motor at all as I use to use a cj18a mini lathe and you could control the speed on that one
      thank you in advance
      #14097
      Neil Mccarthy 1
        @neilmccarthy1
        #508862
        Steviegtr
          @steviegtr
          You can slow down a single phase motor but in doing so will loose the torque needed. It is better to look for a 3 phase motor with 240 windings As 415v star 240 delta motor. Then use a 240v 3ph inverter . to control it. Probably going to cost you in the region of new 300+ quid. 2nd hand if you are lucky 200.
          Steve.
          #508869
          Pete Rimmer
            @peterimmer30576
            Posted by Neil Mccarthy 1 on 21/11/2020 00:13:56:
            Your Drummond's motor's speed is fixed by the 50Hz frequency of mains electricity. Whilst it is possible, it's not practical to alter the way you can with a 3-phase motor.
            Your mini-lathe will have a DC motor which is why you can use a speed controller.
            #508878
            David George 1
              @davidgeorge1
              Be careful the top speed for your lathe with bronze bushes is below 1000 RPM and most speed controlled motors loose power at slow speed on my M Type I can screw cut at 50 RPM with back gear and pleanty of power not so on a friend's variable Chinese lathe.
              David
              #508893
              David Colwill
                @davidcolwill19261
                Posted by David George 1 on 21/11/2020 08:11:01:
                David
                You are right regarding the lathes top speed but torque at low speed shouldn't be a problem as the Drummond has back gear (I think) and this can be used for turning larger diameters and screw cutting etc.
                If you can find a scrap yard willing to let you poke around, you may be able to rumage up a three phase motor for not too much.
                There are any number of cheap inverters from China for £50-£60. I don't have any experience of these (I have one in a box waiting for the time to come available) but others here will have used them.
                David.
                #508902
                Martin Connelly
                  @martinconnelly55370
                  If you go three phase make sure the nominal speed of the three phase motor is similar to that of the current one. The number of poles on a three phase motor determines the nominal speed. A scrap motor may look the part but cause problems of running too slow or too fast at nominal frequency from a VFD.
                  Martin C
                  #508988
                  old mart
                    @oldmart
                    Should you end up deciding to change to a 3 phase motor run from a VFD, then there is a choice of basic types. At 50Hz standard mains frequency, the choice is as follows:
                    2 pole @ 3000rpm
                    4 pole @ 1500rpm
                    6 pole @1000rpm
                    8 pole @ 750rpm
                    The price increases with the number of poles. They all can be controlled with a VFD and the torque values are good between 25 and 75 Hz, (0.5 to 1.5 times their standard speed). Lower frequencies bring a steep dip in torque.
                    #509098
                    Steviegtr
                      @steviegtr
                      David
                      My lathe has a Bronze front spindle bearing & is rated at around 2150 rpm from the single phase as supplied motor. A Super 7B 1977 vintage. I rarely run much above 1000 though.
                      Steve,
                      #509101
                      Henry Artist
                        @henryartist43508
                        Depending on what you intend to use the lathe for, why not just use a motor and speed controller from a mini-lathe?
                        #509894
                        PETER ROACH
                          @peterroach92938
                          Probably not widely known, but split phase, cap run single phase motors can be run from VFDs. These motors are in effect a two phase motor and the generic AT2 VFDs are design to provide control for them.**LINK**
