Driving trolley
Driving trolley
Home › Forums › General Questions › Driving trolley
  • #449561
    Speedy Builder5
      @speedybuilder5
      Looking for plans for a 5" gauge driving trolley – any advice out there please ?
      #27112
      Speedy Builder5
        @speedybuilder5
        Plans for driving trolley
        #449594
          I made a VERY simple 5" trolley, it's under piles of stuff at the moment, but at some point I'll did it out and write it up.
          Basically a frame from 19mm square steel tube, welded up with a cross-bar as a foot rest. Wheels run in ball races fitted to pivoted aluminium blocks with rubber blocks as suspension (a la Mini) which works really well. I made a connector blocks that can take a chain for 5 and left or right hand 3 1/2 use.
          For ground level track the seat (padded leather on plywood) sits on a hollow wooden box. For elevated track, leave out the spacer box, and fit two 'Z' shaped extensions that provide lower, wider footrests.
          It has a disk brake but not fitted as I don't need it with my puny loco
          Edited By Neil Wyatt on 29/01/2020 10:50:27
