Dore Westbury Milling Machine
Home › Forums › Help and Assistance! (Offered or Wanted) › Dore Westbury Milling Machine
  • #329483
    Ian L
      @ianl48580
      Hi, When making a Dore Westbury MKII there was an option for the spindle to have a 3MT and no Myford thread on the spindle. Does anyone know what the diameter of through bore should be and what jaw bar diameter/thread was used for holding the chucks?
      Thanks.
      Ian
      #33110
      Ian L
        @ianl48580
        #329487
        Brian Wood
          @brianwood45127
          Hello Ian,
          I built my DW to the 3 MT specification. The through hole for drawbars is 29/64 inch diameter, I opened mine up a little over what I think the drawing would have shown as 7/16 inches.
          At the time, standard drawbars were given a 3/8 Whit thread; with metrication today's versions are more likely to be M10
          I hope that helps
          #329493
          Ian L
            @ianl48580
            Hi Brian,
            Thank you for the information, very helpful.
            So I can assume the upper part of the spindle assembly came pre drilled at 7/16 diameter.
            Ian
            #329577
            Thor 🇳🇴
              @thor
              Hi Ian,
              I have a milling machine with a MT 3 spindle, and the drawbar for my metric tooling is M12, so 7/16" might be a bit too small.
              Thor
              #329586
              Brian Wood
                @brianwood45127
                Posted by Ian L on 28/11/2017 09:10:00:
                Hi Brian,
                Ian
                Hello again Ian,
                I built my mill over 25 years ago and I simply don't remember that diameter detail now I'm afraid. I can tell you that the upper part of the spindle was inserted into the lower part containing the MT taper and the joint was Loctited. I supported the parts with a chuck, tailstock centre and a fixed steady to centralize the joint while it set. It has never shifted since despite a lot of work, some with big drills using the gearbox to give the low speed and torque needed.
                I did open out the bore some time later with a drill and extension pieces to 29/64 to give a little more internal clearance for a brass ended knock out bar and it should stand opening up still more for an M12 drawbar thread.
                I have not had to do so though so if you are building I would also pin the joint and not just rely on the Loctite
                Regards Brian
