Crankshaft Factory
Crankshaft Factory
Home › Forums › The Tea Room › Crankshaft Factory
Viewing 13 posts - 26 through 38 (of 38 total)
  • #565434
    Dave Halford
      @davehalford22513
      Posted by Peter Cook 6 on 03/10/2021 11:37:03:
      Posted by ega on 03/10/2021 10:59:54:
      What was the process involving rotating a batch inside an enclosure? I thought it looked like some form of heat treatment.
      I assumed it was shot blasting given the surface finish that came out.
      You saw the shot being poured in when the bag was cut open. smiley
      Curses beaten to it face 14
      Edited By Dave Halford on 03/10/2021 20:48:12
      #565448
      john halfpenny
        @johnhalfpenny52803
        Yes MichaelG, of course I saw 'Belarus' on the box, but your post doesn't answer the question
        #565456
        Bill Phinn
          @billphinn90025
          Posted by john halfpenny on 03/10/2021 22:34:39:
          Does this help explain things further?
          #565463
          Clive Hartland
            @clivehartland94829
            It is possible these three throw crankshafts are for a 3 cylinder tractor engine, they seem quite common in some places.
            My farmer friend has one.
            #565466
            Ady1
              @ady1
              Found a couple of links
              https://www.tractorspakistan.com/uk/massey-ferguson-mf240-sale-united_kingdom/
              https://tractors.fandom.com/wiki/Massey_Ferguson_240
              It looks like the old Brit stuff is still popular in some places because it's relatively simple and easy to fix/maintain
              edit: and it has a deluxe seat too
              "The Company has formed joint ventures in several companies to facilitate local manufacture, often to get round import restrictions and or rules on local content. "
              So if your stuff is simple enough you can build it in-country with basic industrial tooling and take a cut
              Edited By Ady1 on 04/10/2021 08:21:15
              #565469
                Sorry, John … I didn’t realise that your comment “Not sure what the Belarus connection is“ was an actual question.
                Being the first person to mention Belarus on the thread … I assumed you just wondered where I got it from.
                I think Bill Phinn as given you the information that you actually wanted.
                Nigel McBurney 1
                  @nigelmcburney1
                  Despite all the modern manufacturing tecniques ,L/R Discovery 6 cylinder diesel crankshafts break all to often , new engines are well over £10k,
                  #565480
                  Ady1
                    @ady1
                    Old Discoverys sound like a bag of spanners jumping about
                    #565481
                    Circlip
                      @circlip
                      Yes Andy, hammers and bench press. many years ago watched in horror as a "technician" inserted the outer race into my wheel hub with a hammer. He was standing next to the bench press. Back street garage? No, VW main agent. This was fourty five years ago, when WE did it properly.
                      Regards Ian.
                      #565485
                        Probably 1970 … we toured the BSA motorcycle factory, where they were building the ‘triples’
                        I watched in amazement as the chap installed the crankcase main-bearing with one deft blow !
                        Ady1
                          @ady1
                          Sounds like 1950s piecework
                          Why take 60 seconds to press one in when you can whack 3 in at 20 seconds a pop
                          #565513
                          Howard Lewis
                            @howardlewis46836
                            Unfortunately, the back street manufacturers, do not have the drawings, or technical knowledge and Engineer back up to make the part correct to spec. When the thing fails early, the engine OEM gets the blame for some substandard part!
                            The quantity being produced suggests a steady market for replacements.
                            We found some "Replacement" lift pumps that had carefully copied a defect that we spotted early on and eliminated from genuine spares. Often these pirates do not really understand what they are making, and so proper heat treatment or exact material composition tends to be ignored.
                            In a market with no previous experience, an engine that wears out or fails after 500 hours is thought to be the norm, rather than 5 or 6,000, hours before needing even a minor overhaul for a genuine article.
                            In such an area, anything that is more powerful than a donkey, and can carry 3 people, and their goods, to and from market without getting tired, is considered to be an improvement..
                            I have seen a pick up so overloaded.that the front wheels left the road at every slight bump!
                            Remember the single cylinder tricycle truck being loaded to take away the finished product, in the video!
                            A VW Beetle started from cold by lighting a fire under the sump!
                            A tractor, power tested by counting how many bricks, on a pallet, it can pull up a hill.
                            Parts joined using different threads, "But, it's got a thread on it" (1/4 BSP onto M12! )
                            Different worlds from ours.
                            #565520
                            Greensands
                              @greensands
                              Where were all the hard spots?
