Clarke CMD10 motor problem. H E L P !
Home › Forums › General Questions › Clarke CMD10 motor problem. H E L P !
Viewing 21 posts - 1 through 21 (of 21 total)
  • #135519
    Eric Thacker
      @ericthacker25502
      First of all the very helpful lamp labelled 'unnormal' came on, ( what does it do ?)……..and then nothing, no motor activity and I'm pretty sure the motor and controller are U/S. there are open circuit segments on the motor whereby if you connect it to a low voltage DC supply it stutters round as long as you spin it.
      Has anyone replaced the motor , perhaps with a 3 phase and inverter ? If so what wattage motor ? Is there anywhere to get a new motor /controller at a reasonable price, I haven't asked Clarke yet but I suspect it will be astronomical.
      I cannot live a normal life without this machine, I'm retired and it's always in action doing some job or other.
      Cheers
      Eric Thacker
      #22953
      Eric Thacker
        @ericthacker25502
        Where to get motor and controller from in the UK.
        #135529
        Eric Thacker
          @ericthacker25502
          The cost from Clark for motor and board is almost exactly £250.
          #135530
          Eric Thacker
            @ericthacker25502
            Thanks for reply, much appreciated.
            I never run the machine in reverse this happened normally.
            I tried everything , pull the plug and wait and in the end I took the motor off and it's U/S.
            I've had the price from Clarke and the total comes to almost exactly £250.
            #135531
            nigel jones 5
              @nigeljones5
              Check the brushes in the motor, but most likely the pcb is shot – ive had two do this and cant get em repaired! In the end I used a couple of bridge rectifiers and ran it on a fixed speed. My clarke lathe went the same way, replaced that with a drill motor and switch – now fixed speed also.
              #135532
              nigel jones 5
                @nigeljones5
                and…you cant just swap one board for another without checking what you have, there are several different ones.
                #135535
                Eric Thacker
                  @ericthacker25502
                  Thanks for replies. I've been on the Arc euro site and it will cost £77 +£87 which is better than Clarke.
                  I've identified the correct board , I took a picture and have the number, it's the one with the single mosfet.
                  When you fitted the drill motor what motor did you use and did you rectify the mains 240 volts or drop it down ?
                  #135610
                  Eric Thacker
                    @ericthacker25502
                    Tee hee, works a treat.
                    https://app.box.com/s/plq3ungxat14pi28pb7k
                    Edited By Eric Thacker on 15/11/2013 16:25:29
                    #135630
                    nigel jones 5
                      @nigeljones5
                      The drill motor was from a pedestal drill so didnt need to add anything – loads more power and I could easily halve the speed if I could be bothered – glad you got your mill fixed, mine is sat in a sorry heap in the corner!
                      #135643
                      John Rudd
                        @johnrudd16576
                        Posted by Eric Thacker on 15/11/2013 16:24:20:
                        Great idea using a power tool…….
                        I've repaired numerous controllers from these little machines….agreed they are a pain, but spare boards are extortionate……from mm/clarke
                        #135651
                        Eric Thacker
                          @ericthacker25502
                          The old Black and Decker motor ( my Dad's from the sixties ) was way too fast but using an AC power controller got it down to working revs ( what are they ? ) and it's got more power that before, its a 400 watt motor but probably halved but still 200.
                          At least I get the chance to have a look at the board while the miller carries on.
                          Thanks for all your help, much appreciated.
                          #135655
                          Eric Thacker
                            @ericthacker25502
                            I forgot to mention…… luckily the motor was going the right way ( anti-clock) and being AC had it not it was going to be a bugger if the wrong way.
                            Although it's a universal AC/DC motor , they don't reverse very readily.
                            in theory it's relatively simple to reverse the field coil/ armature windings relative to each other but in practice it doesn't work out on AC, something to do with the angle of the brushes ( I've done it ) and the motor, in reverse, goes slower and sparks like the clappers. I've not tried it on DC.
                            #136195
                            Eric Thacker
                              @ericthacker25502
                              I've finally solved it permanently……..scrounged 3 phase motor using a shared Mitsubishi inverter that also works my pedestal drill motor via a changeover switch. More powerful, set up so the E.stop button stop / starts it and I've set up the selector switch so as to provide 3 speeds although if I use the inverter control panel I can have variable speed + reverse.
                              That's it now, job done – at a cost of…… nothing.
                              See picture here………
                              Edited By Eric Thacker on 22/11/2013 18:44:33
                              #136201
                              nigel jones 5
                                @nigeljones5
                                looks brilliant…but those poxy nylon gears wont last long!!
                                #136208
                                Eric Thacker
                                  @ericthacker25502
                                  You're right , I've been thinking about the gears.
                                  Not a lot of options really, I'll have to wait and see.
                                  #136210
                                  Michael Cox 1
                                    @michaelcox1
                                    Posted by Eric Thacker on 23/11/2013 06:54:04:
                                    Convert it to belt drive. See:
                                    #136215
                                    Eric Thacker
                                      @ericthacker25502
                                      The engineering is absolutely excellent on both the improved gears and the belt drive solutions….. wonderful.
                                      Now then what next ……..
                                      #136236
                                      Eric Thacker
                                        @ericthacker25502
                                        BTW, if you blow up the first photo with the drill body motor you can see at the rear of the machine another very handy mod that I did.
                                        It's a battery drill motor mounted vertically so as to provide a rise and fall on the whole head, the 2 gears came from RS , it's always being used, to wind it up and down with the handle was a real nuisance.
                                        The motor was originally 9.6 volts but it's been run at nearer 30 for the last 10 years or so without problem.
                                        #136243
                                        Eric Thacker
                                          @ericthacker25502
                                          Here's a picture……..
                                          Eric Thacker
                                            @ericthacker25502
                                            What cutter did you use to make the gear ?
                                            I fancy a bash at it I've never made a gear before.
                                            I presume you have a dividing head.
                                            #136296
                                            Eric Thacker
                                              @ericthacker25502
                                              laugh
                                              Edited By Eric Thacker on 24/11/2013 09:53:53
