Car Boot Find! Part Missing?
Home Forums Beginners questions Car Boot Find! Part Missing?
Viewing 25 posts - 1 through 25 (of 25 total)
  • #181154
    Martin King 2
      @martinking2
      Hi all,
      Found this nice little item at a car boot sale, looks like all it needs some tlc.
      I have zero knowledge of these engines from a get it running point of view so thought I would just clean it up carefully first and evaluate it later with some help from here hopefully.
      I started with the component shown and when I took it apart for cleaning there was this stray nut inside the cylinder part just rattling around. There is also the hole at the bottom so I wonder if a part is missing?
      Any thoughts welcome please?
      Regards, Martin
      #7493
      Martin King 2
        @martinking2
        #181163
        Martin King 2
          @martinking2
          car boot engine 4car boot engine 3car boot engine 2Here are the pics I left out last time! blush
          car boot engine 1
          #181186
          Bazyle
            @bazyle
            It looks like it might be an oil trap for the steam on the way to the chimney, It would need an in, an out and a tap at the bottom to drain off the condensate and oil trapped. Are you sure it is part of the engine?
            #181187
            Martin King 2
              @martinking2
              Hi, it is definitely part of the engine as shown in the pics, the right angled pipe from the cylinder goes to the top union. You can see wher it sits on the base plate.
              martin
              #181188
              nigel jones 5
                @nigeljones5
                it looks odd to me…I cant see an oiler so why an oil trap?
                #181191
                Brian Rice 1
                  @brianrice1
                  It's definitely not part of the Stuart engine I can not see why you would have it connected to the exhaust steam pipe also if you look at the rest of the plant it's not age related. But what do I know wink
                  #181195
                    My guess is that it's an add on condenser, probably just someone's experiment to see if they can stop the engine spitting hot water everywhere, rather than a quest for efficiency..
                    Martin Cottrell
                      @martincottrell21329
                      Posted by fizzy on 25/02/2015 19:02:15:
                      Fizzy, it looks like there is a displacement lubricator fitted to the steam chest so it could easily be an oil/condensate trap. If you look carefully at the baseplate in the last photo, you can see where the component has been mounted directly under the union on the end of the exhaust pipe.
                      Martin, if it is indeed an oil & condensate trap there should be some form of plug or tap at the bottom to drain down the accumulated oil & water. A few more details of the component would be helpful, is the lid removable, how is it fixed, is the central hole in the bottom of the pedestal blind or is it drilled through into the cylinder?
                      Regards (another!) Martin.
                      #181203
                      Martin King 2
                        @martinking2
                        Hi all, you have already left me behind with talk of displacement lubricators etc!
                        I have cleaned up the boiler and housing and burner so will take some more detailed pics and post tomorrow.
                        The guy at the car boot did not know what it was, just said some sort of kids toy!
                        It has obviously been working at some time as the bottom of the boiler was 1/8" deep in soot and about a dozen dead spiders!
                        Regards, Martin
                        #181205
                        Martin Cottrell
                          Martin, you have the makings of a nice little steam plant there, too good for a kids toy but it definitely has the makings of a big boys toy!! I trust the sellers' ignorance allowed you to purchase it at "broken toy" rates?! wink
                          Regards Martin.
                          #181209
                            Yes oil trap or condenser witha tap or drain off valve missing from the bottom. I take it that bit has been cleaned up by you and obviously part of teh steam plant as you can see the three old mounting holes in the base.
                            The displacement lubricator is the small cylinder on teh side of teh engine with teh Tee handle plug in teh top, as a small amount of steam condensates in it the water will sink to teh bottom and the oil in it will float to th etop where it is slowly carried into the engine and lubricates the moving parts. This oil can also be carried out of teh exhaust so the steam/oil mix goes into a seperator to take the oil out.
                            J
                            #181211
                            John Olsen
                              @johnolsen79199
                              Hi Martin K, It is a Stuart S50 mill engine. The machined set of parts for the engine currently costs GBP384.50, not including VAT. Hopefully you did not pay anything like that. The boiler may be Stuart as well, but is not in their current catalogue. The Brass bit is an add on that someone has come up with, most likely an oil separator. **LINK**
                              The displacement lubricator is the bit on the side of the steam chest with a couple of T handled screw pieces showing, there should be another one underneath. The way it works….you fill it up with oil via the top plug. When the engine is running it is cooler than the steam, so a little steam comes in and condenses. This displaces some oil, which flows into the steam chest. (Steam and oil go through the one connection in opposite directions.) The screw on the side adjusts the flow. When the run is finished you can drain out the water and any remaining oil via the screw on the bottom. They work quite well for an engine running at a steady speed. They are not so good for an engine where the speed varies a lot, as the lubricator will cool down when running or lightly loaded, then condense a lot of steam and over oil the engine when the pressure is suddenly increased. But they are perfectly good for this sort of engine, which does not need a lot of oil anyway.
                              Ian Parkin
                                @ianparkin39383
                                The boiler i'm sure is a stuart 501 its missing its chimney though
                                Ian
                                #181297
                                Martin King 2
                                  @martinking2
                                  Hi all, Yes I have cleaned up the brass item with the loose nut and have so far done the boiler as well, will post some more pics later today. The whole lot was a tenner so quite happy there! I have had the engine running off my air line and it seems to go very well indeed. Where might I get a drain tap for the missing part or can I make one?
                                  Correct , the boiler is a STUART 501 has the number in the casting and there is a chmney with it but interestingly it has NESTHILL on it so I think it was made from an old grease gun body, but looks very nice with the brass rings etc.
                                  Martin
                                  #181351
                                  Martin King 2
                                    @martinking2
                                    Here are some more pics showing the connections to the newly cleaned brass part with the loose nut:
                                    #181353
                                    Martin King 2
                                      @martinking2
                                      Some of the connections seem to have alloy washers in very poor condition, almost like the copper sort that used to crush when tightened and were replace when undone. Are thes still avilable. It also looks like this might have had a steam pressure gauge at some time but the pipe is soldered closed.
                                      I will start cleaning the engine in the next day or two but I think that I have to be a bit careful not to disturb the timing rod and eccentric.
                                      #181395
                                        All I can say is that's a very nice find for a tenner!
                                        ianj
                                          @ians
                                          Martin
                                          "These are 3 fold copper washers for steam fittings to help seal the joint":-**LINK**
                                          Ian
                                          #181439
                                          Ian S C
                                            @iansc
                                            No one has mentioned it, but I think the engine is a S50(I suppose everyone knows that).
                                            Ian S C
                                            #181441
                                            Nicholas Farr
                                              @nicholasfarr14254
                                              Posted by John Olsen on 25/02/2015 20:46:40:
                                              Hi Martin K, It is a Stuart S50 mill engine. The machined set of parts for the engine currently costs GBP384.50, not including VAT. Hopefully you…………………………………………………………
                                              Hi Ian, I think John did.
                                              Regards Nick.
                                              #181442
                                              Martin King 2
                                                @martinking2
                                                Posted by Ian S C on 27/02/2015 08:42:25:
                                                Ian S C
                                                I didn't! blush
                                                Ian
                                                Thanks for the link , I will get a few to replace the bad ones.
                                                Is there anythng in particular to be careful of when stripping the engine for cleaning? Timing etc?
                                                Should I make marks for correct re-assembly?
                                                Martin
                                                #181443
                                                  Just make a note of where the eccentric is in relation to the crankshaft throw.
                                                  #181596
                                                  Ian S C
                                                    @iansc
                                                    And take note of the position of the cylinder head in case the holes are not evenly spaced.
                                                    Sorry missed that it had been noted as a S50.
                                                    Ian S C
                                                    #182220
                                                    Steve Pavey
                                                      @stevepavey65865
                                                      A similar one on eBay, with some good photos to compare with yours.
                                                      http://www.ebay.co.uk/itm/Vintage-Model-S50-Mill-Steam-Engine-501-Boiler-by-STUART-Models-/141591439303?pt=LH_DefaultDomain_3&hash=item20f781e7c7
                                                      Edited By Steve Pavey on 05/03/2015 13:21:52
