Brass paint
Brass paint
  • #313122
    Rod Ashton
      @rodashton53132
      Would anybody have a solution for a paint to give some appearance of brass. Possibly a modified gold?
      #30626
      Rod Ashton
        @rodashton53132
        Imitating Brass Paint
        #313124
        roy entwistle
          @royentwistle24699
          What material are you painting ?
          #313128
          Rod Ashton
            @rodashton53132
            Finely sealed and sanded wood and MDF. To 400 grit. Just found some sprays on the bay. But not much coverage for your bucks. Trying to reproduce/model, a Burrell firebox door so quite a big surface, even just the lettering and rings.
            #313134
              One of the buffable paints like Gunze Sangyo's "Mr metal" would give a good polished look
              link
              This resin figure's plate work is done with it. buffs up quite well though not tried it or large areas, figure is 120mm tall.
              Edited By JasonB on 21/08/2017 09:30:38
              #313139
              Brian G
                @briang
                Another option might be to use brass leaf (I didn't even know it was available).
                #313142
                  That looks like a king… total guess, is it Henry V?
                  #313149
                  Roderick Jenkins
                    @roderickjenkins93242
                    The coat of arms pin points it pretty closely
                    Rod
                    #313163
                    David Standing 1
                      @davidstanding1
                      Posted by Neil Wyatt on 21/08/2017 09:58:31:
                      Is Super Adept Man jealous of the outfit? wink 2 cheeky
                      #313165
                        Charles I of Albert or Charles d'albret. Constable of France who lead the French against Henry at Agincourt.
                        Rod there are no lions just the three flur de Les on the blue background of France
                        Edited By JasonB on 21/08/2017 11:35:49
                        #313166
                        David Standing 1
                          @davidstanding1
                          Meanwhile, back to the original question……
                          As it is going on wood, you could try a gilding product such as this:
                          Phil P
                            @philp
                            Hi Rod
                            I assume you mean a "smokebox" door ring on the front of an engine as opposed to the firebox door ?
                            Are you sure you are looking for a brass finish, they were polished cast iron on a lot of full size engines, it was probably only a showmans engine that was fitted with a brass ring.
                            Phil
                            #313186
                            CHARLES lipscombe
                              @charleslipscombe16059
                              All so-called "Gold paint" is made from brass or bronze powders. However there are many different brass/bronze alloys used so that different shades can be obtained e.g. antique gold, bright gold etc. These paints would be available from signwriters or artists suppliers. However these paints are often not glossy.
                              Would it be acceptable to use a flat paint and then a spraypak of clear gloss acrylic?
                              Chas
                              #313187
                              Steve Pavey
                                @stevepavey65865
                                "Treasure Gold" is another alternative – I bought some from a local art shop years ago, but I see several Amazon resellers have it. Also available in bronze and silver I think. It's a wax paste that can be buffed, and thinned with white spirit. I was quite impressed with the results.
                                #313191
                                Ray Lyons
                                  @raylyons29267
                                  I bought a can of spray from Wilko which did a great job on metal.
                                  #313192
                                  Rod Ashton
                                    @rodashton53132
                                    Phil – yes I meant a smokebox door.
                                    I have not purchased anything yet. But much food for thought. Thanks to everyone.
                                    #313197
                                    Rod Ashton
                                      @rodashton53132
                                      Phil – you posed me a question there. Well I looked through a couple of hundred shots of various smokebox`s and valve plates that I took yesterday at the Weald and Downland show. Burrells, Alchins, Garretts, Fowlers, Claytons, Dodmans, Fosters,McLarens, Aveling & Porter. With no exceptions all the lettering rings where brass.
                                      Actually found an old wilco can of gold spray, thanks to Rays reminder. Sprayed a test piece which had been finely sanded and primed with black. It was quite promising. See what another coat can do in the morning. I believe a clear matt topcoat on that may be near the mark.
                                      #313286
                                      Phil P
                                        @philp
                                        Granted most probably are brass now, but they were made of iron on some Burrells as well.
                                        THE "BURRELL" PATENT ENGINE
                                        https://en.wikipedia.org/wiki/Charles_Burrell_%26_Sons#/media/File:Burrell_6NHP_GP_enginebj7155.JPG
                                        Phil
                                        #313287
                                        William S
                                          @williams
                                          Hello all
                                          I belive humbrol makes a brass effect paint, not sure if its part of the "metalcote" line of paints I have had good results with the steel effect paint. Also brass effect paint appears to be offered by Hammerite.
                                          William
                                          #313294
                                          Ian S C
                                            @iansc
                                            When I built this about twenty years ago, Humbrol brass paint was used, I think the little tin is still around somewhere.
                                            Ian S C
                                            Allchin Royal Chester
                                            #313295
                                            Sandgrounder
                                              @sandgrounder
                                              Posted by Ray Lyons on 21/08/2017 14:21:35:
                                              You beat me to it, I repainted an old metal loudspeaker, after preparing the aluminum horn and priming with zinc chromate, I used Wilko's gold spray on the outside and black in the mouth, it's actually passed the ultimate test and is now allowed to stand on a cabinet in the dining room.
                                              Rod Ashton
                                                @rodashton53132
                                                Have ordered a can of the Plasti-Kote Brass, believe this is possibly the old Valspar? This after seeing a faux brass plaque locally. – Interestingly it had been prepared with heated (H/A gun) two part epoxy. The heating allows it to run like paint apparently. Will experiment with this as wood grain effect had been completely eliminated.
                                                Thanks again for all the info.
                                                #313300
                                                  I have seen the Rustins Plastic Coating applied like that, the heat allows it to flow and brings any bubbles to the surface
                                                  #313302
                                                    Posted by JasonB on 21/08/2017 11:30:06:
                                                    See, I got the date spot on
