Boxford C – removing headstock
Home › Forums › Manual machine tools › Boxford C – removing headstock
  • #471985
    Grindstone Cowboy
      @grindstonecowboy
      Hi all
      Just seeking some advice. It appears to be very easy to remove the headstock assembly on my Boxford model C – just two bolts underneath and it should just lift off the bed. Am I right? And more to the point, is it an easy matter just to replace it and not upset the alignment of anything? Is there a specific torque setting for the bolts when replacing?
      Hopefully there's no hidden shims or setscrews that would need resetting or anything, it looks like it should just realign itself using the inverted V shape of the bedways.
      Thinking of doing this to a) make it lighter to lift up onto the cabinet (I've only got my wife to assist at the moment) and b) make it easier to give everything a good clean and possibly paint.
      There's also, I think, something up with the backgear selection, but I'll start a separate thread for that if I can't work it out.
      So, drawing on the collective experience here, am I likely to be OK doing this or will I mess it up completely?
      Thanks,
      Rob
      #13895
      Grindstone Cowboy
        @grindstonecowboy
        Is this fraught with danger?
        #471988
        Pete Rimmer
          @peterimmer30576
          The headstock site on the bedway vee so it's alignment is assured when you replace it so long as you are very careful when handling it and setting it down so as not to bruise the underside faces.
          #471989
          Grindstone Cowboy
            @grindstonecowboy
            Thank you Pete, that's what I was hoping for. yes
            #472007
            RichardS
              @richards31161
              Just to a little to Pete Rimmers comment.
              You will probably need to shorten a spanner to loosen/tighten the clamp bolt at the RHS of the headstock.
              Before you refit the headstock, clean the bedways where it normally sits, clean the mating faces of the headstock, lubricate both with slideway oil and wipe off the excess.
              Before you tighten the the clamp bolts check for changewheel alignment.
              #472010
              Grindstone Cowboy
                @grindstonecowboy
                Thank you Richard, a good tip about the spanner and the oil. It seems to sit absolutely flush with the end of bed, but I will check – wouldn't have thought about the changewheels if you hadn't mentioned it, always something more to learn.
                Best regards,
                Rob
                #472022
                Clive Brown 1
                  @clivebrown1
                  The bolt holding the RH end of the headstock is a right bu66er to access. Picture shows the spanner I adapted to loosen / tighten it. It's an old "King-Dick" so it didn't fracture when I bent it. Size is 5/16" BSF.
                  #472028
                  Grindstone Cowboy
                    @grindstonecowboy
                    Thank you Clive, I will have a look at spanners tomorrow and see what I can do. Hopefully the bolts won't be ridiculously tight.
                    All the best,
                    Rob
