Blow torch recomendations
Home › Forums › Help and Assistance! (Offered or Wanted) › Blow torch recomendations
  • #339374
    Chris Evans 6
      @chrisevans6
      Can anyone recommend a suitable Propane ? torch for brazing. I need to replace a steering stem brazed into the bottom yolk of a motorcycle and also warm up tubes to bend back to shape.
      #33147
      Chris Evans 6
        @chrisevans6
        #339388
        Oldiron
          @oldiron
          A bullfinch is probably the way to go. Do a search for brazing and you will find loads of posts.
          #339390
          Keith Hale
            @keithhale68713
            Hi Chris
            Start with a Sievert torch, variable regulator and a 2941 burner.
            The kit can be readily adapted by simply changing burners to go from 0.25 kw to 84kw oh heat.
            They are readilly availablehttp://www.cupalloys.co.uk/sievert-heating-equipment/
            The kit is supplied with all the technical help you may require to make your project a success.
            regards
            keith
            Edited By CuP Alloys 1 on 01/02/2018 21:03:42
            #339405
            Vic
              @vic
              Sievert are one of the best and the cheapest place to buy them used to be Hamilton Gas Products, it’s where I bought all mine.
                Is it Braze or silver solder, if Braze then you will have a job with just propane and I doubt the Bullfinch one will be able to get enough heat into a large part like that. Probably have to go with oxy-propane.
                #339424
                  Chris,
                  Particularly for the second of your requirements:
                  Have a look at Sievert's 'Cyclone Burners'  **LINK**
                  http://www.sievert.se/wp-content/uploads/2014/11/Sievert-International-Catalogue.pdf
                  The availability of these [which are excellent] might well inform your choice of 'system'.
                  Edited By Michael Gilligan on 02/02/2018 07:42:28
                  #339500
                  Chris Evans 6
                    @chrisevans6
                    Thanks for all the replies, I've had a kind offer from a local member to go and look at his kit which will help the decision. Reading other answers I may need something with more "Oumph" to braze the sort of section I am looking at doing.
                    #339533
                    Matt Martin
                      @mattmartin86844
                      I personally use a Rothenberger quick fire on map bottles. Can’t fault that thing, it’s gets stainless manifold flanges glowing so it would certainly be hot enough
                      #339537
                      SteveM
                        @stevem36008
                        There are a number of brazing videos on on YouTube posted by a guy who calls his channel 'Xynudu' (AKA Rob) He uses and recommends a Bullfinch 4100 and this is one of his videos:
                        Bullfinch Brazing Torch
                        The torch looks like a good piece of kit and I've promised myself one for this years birthday present smiley
                        Edited By SteveM on 03/02/2018 00:29:52
                        #339541
                        the artfull-codger
                          @theartfull-codger
                          I've used sievert for over 40yrs gradually building up a full set of nozzles & they're one of the best, till I got a flamefast hearth gas/air blower it only uses a few psi propane but it really gives out some heat plus I have a smaller torch for small jobs,the sieverts only used away from the workshop now.
