Black Bar
Black Bar
Home Forums General Questions Black Bar
  • #26837
    Graham Williams 11
      @grahamwilliams11
      #428937
      Graham Williams 11
        @grahamwilliams11
        Is black, presume hot rolled, round steel bar generally or always of EN3B spec???
        Cheers
        GW
        #428938
        Anonymous
          EN3 is the most common spec, but not the only one. You can get EN8 as black bar.
          #428944
            You can even get EN1A but not from many of the usual ME suppliers.
            #428947
            vintage engineer
              @vintageengineer
              Be very careful with mild steel black bar. This is normally recycled steel and full of all sorts of crap!
              #428960
              David George 1
                @davidgeorge1
                I have EN 40B black bar and EN 32 black bar so beware what you buy and suplier.
                David
                #428976
                John MC
                  @johnmc39344
                  My preference is to always go for black bar if it's available in the grade of steel I want to purchase. Two reasons, its usually cheaper than bright drawn, also less prone to distortion during machining.
                  If steel is sold as EN3, black or cold drawn it will be EN3. All "new" steel will contain recycled steel, steel being one of the most recycled materials.
                  duncan webster 1
                    @duncanwebster1
                    Posted by John MC on 14/09/2019 18:02:50:
                    And a lot of cast iron is made from steel scrap by adding carbon. The reason I think is you know what you are starting with, so you have a chance of knowing what you finish with.
